johnbil 3 Posted September 29, 2021 Posted September 29, 2021 Not sure if this is the correct forum for this question. If not, I apologize. It seems that Emby is listing the incorrect TV episode info more and more lately. When I put an episode into a show's folder, it shows the correct show/series with the right images for the show, but the various episodes all have the same episode titles and info/descriptions. I usually name a file something like this - "Archer 12-01.mkv". Am I doing something wrong? Do I need to adjust the metadata source or is this this just a flaw in Emby? Regards...John Windows 7 SP1 / Emby 4.5.4.0 / Amazon FireTV
Happy2Play 9802 Posted September 29, 2021 Posted September 29, 2021 (edited) 16 minutes ago, johnbil said: I usually name a file something like this - "Archer 12-01.mkv". Can you go over a specific example with library settings and structure. But I would have to test but this is not a official supported naming scheme. Edited September 29, 2021 by Happy2Play
johnbil 3 Posted September 30, 2021 Author Posted September 30, 2021 Never mind. Sorry. I figured out what I was doing wrong. Instead of naming the file say "Archer 12-01.mkv", it should be in this format "Archer S12E01.mkv". That brings in all the info correctly. 1
