DamianSommer 0 Posted September 27, 2021 Posted September 27, 2021 (edited) Hi all, I'm in a predicament where I accidentally set Genre Cleaner to only Action, which then did a purge of all my other genres. I'm trying to reset the metadata for all my movies to their base state, but have hit many snags. What I have tried: I have deleted my library.db file in the data folder of my server and ran "Scan media library" several times now, once with genre cleaner uninstalled, once with genre cleaner with no settings in it, and several times with the genre cleaner with a few different genres listed. Deleting my library.db file doesn't seem to be clearing the genres and refilling them in the way I'm expecting. An example: The film Arrival (2016) should have, according to TMDB, Drama, Science Fiction, and Mystery as its genres. I just ran a full library scan, with Genre Cleaner having all three of those genres in it. However Arrival in my library is listed as solely Science Fiction. If I manually click Refresh Metadata, voila, it's perfect. So my main question here is, how do I automate refreshing the metadata throughout my whole library? Edited September 27, 2021 by DamianSommer
Abobader 3485 Posted September 27, 2021 Posted September 27, 2021 Hello DamianSommer, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Solution ebr 16309 Posted September 27, 2021 Solution Posted September 27, 2021 8 minutes ago, DamianSommer said: So my main question here is, how do I automate refreshing the metadata throughout my whole library? Hi. Select "Refresh Metadata" on the library itself. 1
Luke 42198 Posted September 27, 2021 Posted September 27, 2021 Also check your library options and make sure MovieDb is the highest priority movie fetcher, if that's where you want genres to come from.
DamianSommer 0 Posted September 27, 2021 Author Posted September 27, 2021 1 hour ago, ebr said: Hi. Select "Refresh Metadata" on the library itself. Somehow didn't click that this would work. Thank you!
