Luke 42198 Posted September 28, 2021 Posted September 28, 2021 8 minutes ago, LeidenSpain said: The point is that only the MiStick gives me problems, if it were a proxy problem, it would also give me problems with mobile phones and computers when I'm off the network, right? No, that's not necessarily true. For example, if you setup https, each device will have it's own rules in terms of what SSL certificates it will trust. 1
ebr 16309 Posted September 28, 2021 Posted September 28, 2021 Hi. Also, if the proxy is stripping headers, that could manifest differently in the different apps as I indicated above. Please try connecting directly to the local IP address as a test. Thanks. 1
LeidenSpain 33 Posted September 28, 2021 Author Posted September 28, 2021 3 minutes ago, Luke said: No, that's not necessarily true. For example, if you setup https, each device will have it's own rules in terms of what SSL certificates it will trust. ah, i didn't know that. One more thing that I have learned
LeidenSpain 33 Posted September 28, 2021 Author Posted September 28, 2021 (edited) 4 minutes ago, ebr said: Hi. Also, if the proxy is stripping headers, that could manifest differently in the different apps as I indicated above. Please try connecting directly to the local IP address as a test. Thanks. ok, let's see if I use to touch the MiStick Edited September 28, 2021 by LeidenSpain
LeidenSpain 33 Posted September 28, 2021 Author Posted September 28, 2021 10 minutes ago, ebr said: Hi. Also, if the proxy is stripping headers, that could manifest differently in the different apps as I indicated above. Please try connecting directly to the local IP address as a test. Thanks. eh, how good you are So if it works, if I put the local IP of the server I have connected without problems.
ebr 16309 Posted September 28, 2021 Posted September 28, 2021 Okay, so that points strongly to the proxy stripping headers. We've seen this before and I'm pretty sure that the settings created by @pir8radio solve that problem. Search in the server section of the forum for those settings... 1
LeidenSpain 33 Posted September 28, 2021 Author Posted September 28, 2021 10 minutes ago, ebr said: Okay, so that points strongly to the proxy stripping headers. We've seen this before and I'm pretty sure that the settings created by @pir8radio solve that problem. Search in the server section of the forum for those settings... ok, I'll see to see, because I don't use NGINX directly, I use Nginx Proxy Manager (by interface), so I didn't have to touch the configuration files. I will tell you if I have managed to make it work
LeidenSpain 33 Posted September 29, 2021 Author Posted September 29, 2021 I really liked the introduction of the post, because it has been as what I have been saying now I am fighting with the proxy, since it gives me the error "worker_processes". When I get it to work I confirm
pir8radio 1313 Posted October 1, 2021 Posted October 1, 2021 On 9/29/2021 at 11:46 AM, LeidenSpain said: I really liked the introduction of the post, because it has been as what I have been saying now I am fighting with the proxy, since it gives me the error "worker_processes". When I get it to work I confirm you can remove that worker processes line in the config.. its probably pasted into the wrong spot.. 1
LeidenSpain 33 Posted October 1, 2021 Author Posted October 1, 2021 3 minutes ago, pir8radio said: you can remove that worker processes line in the config.. its probably pasted into the wrong spot.. I did that test at the time, but it showed another error. Clearly looking for a file, but it is not where you expect
Luke 42198 Posted October 1, 2021 Posted October 1, 2021 2 hours ago, LeidenSpain said: I did that test at the time, but it showed another error. Clearly looking for a file, but it is not where you expect What error? What file do you think it's looking for? 1
LeidenSpain 33 Posted October 1, 2021 Author Posted October 1, 2021 3 hours ago, Luke said: What error? What file do you think it's looking for? I am dealing with the topic in this thread. More than anything that I would not like to duplicate the threads, that you must already be quite busy.
LeidenSpain 33 Posted October 2, 2021 Author Posted October 2, 2021 On 9/28/2021 at 11:53 PM, ebr said: Okay, so that points strongly to the proxy stripping headers. We've seen this before and I'm pretty sure that the settings created by @pir8radio solve that problem. Search in the server section of the forum for those settings... sorry i got tired of fighting with the proxy and always losing. Is there a possibility to get around this problem by reinstalling emby or the proxy? Regads
