skinny1962 2 Posted September 26, 2021 Posted September 26, 2021 Live TV XML TV Guide is only downloading 24 hours of guide making it hard to schedule recordings. I have Emby Premiere so I should be able to get 2 weeks worth of guide downloaded instead of just 24 hours. Any ideas?
Luke 42243 Posted September 26, 2021 Posted September 26, 2021 Hi, have you looked at the contents of your xml guide? It probably only has 24 hours of data at a time.
Carlo 4561 Posted September 26, 2021 Posted September 26, 2021 Hi, what's your guide source? Emby's built in guides for US, CA & UK support up to 14 days of coverage. If you aren't using Emby's guide source then Emby can only pull as many days as in the XML file.
