Luke 42246 Posted October 5, 2021 Posted October 5, 2021 @wrick17 are you still having an issue with this?
wrick17 2 Posted October 5, 2021 Author Posted October 5, 2021 1 minute ago, Luke said: @wrick17 are you still having an issue with this? Yes, still doesn't convert TrueHD to Dolby, it plays in PCM stereo. But otherwise it works fine.
ebr 16338 Posted October 5, 2021 Posted October 5, 2021 In the Playback settings in the app, is there an option for TrueHD?
wrick17 2 Posted October 5, 2021 Author Posted October 5, 2021 8 minutes ago, ebr said: In the Playback settings in the app, is there an option for TrueHD? There's a TrueHD passthrough but that's disabled
ebr 16338 Posted October 5, 2021 Posted October 5, 2021 13 minutes ago, wrick17 said: There's a TrueHD passthrough but that's disabled Can you please send another log from the app when playing a trueHD item. You can send it right from the playback screen just a few seconds after the item starts. Thanks.
wrick17 2 Posted October 5, 2021 Author Posted October 5, 2021 5 minutes ago, ebr said: Can you please send another log from the app when playing a trueHD item. You can send it right from the playback screen just a few seconds after the item starts. Thanks. Done. It's for IronMan 2008
ebr 16338 Posted October 5, 2021 Posted October 5, 2021 Hi. Can you please set your server logging to debug (switch at top of logs view in dashboard) then restart the server and play that item again for a few seconds and then attach the server log here? Thanks.
