TXK57 36 Posted September 25, 2021 Posted September 25, 2021 I'm running nvidia shields for my platform of choice. When I go to logout and switch users this works but it will not stay logged out. If I close the app and open it the last person logged in is now logged in. On a side not is there a way to have just a num pad come up if you are using pin? After typing either pin or password you have to hit next, then done, then go down to ok. The login seems a little clunky.
Solution GrimReaper 4899 Posted September 26, 2021 Solution Posted September 26, 2021 6 hours ago, takeittothemax said: When I go to logout and switch users this works but it will not stay logged out. If I close the app and open it the last person logged in is now logged in. Likely you have "Remember last user" selected in Settings>Startup tab. Switch to "Show login screen". 6 hours ago, takeittothemax said: On a side not is there a way to have just a num pad come up if you are using pin? AFAIK no, but you can opt for "Use custom d-pad entry", which will enable you to enter pin by remote wheel only.
ebr 16338 Posted September 26, 2021 Posted September 26, 2021 Hi. Please let us know if the above answers your questions. Thanks.
TXK57 36 Posted September 26, 2021 Author Posted September 26, 2021 Thank you guys for the fast response on this! This was the answer to both problems. 1
