Cyberwill 1 Posted September 25, 2021 Posted September 25, 2021 hello I was on docker and just saw that Emby was working on DSM7 so I just installed emby on my ds1621xs + server from the site with the 64 bit spk. no installation problem but in the libraries I can see my volume my folder but if I click on the link it erases. In my server I do not see a user and a folder created by Emby so I cannot give any rights. how to do thank you (sorry for my english)
FrostByte 5454 Posted September 25, 2021 Posted September 25, 2021 Under DSM7 the Emby user is now a "System internal user". Just click the dropdown box to change it and then give permissions as shown below
Cyberwill 1 Posted September 25, 2021 Author Posted September 25, 2021 I don't have a MyEmbyMedia folder?
FrostByte 5454 Posted September 25, 2021 Posted September 25, 2021 Just change "MyEmbyMedia" folder to whatever shared folder you're using for your media. However, the procedure is the same and you won't see an "emby" user until you change the dropdown box to system internal user. Then you should see "emby" user
Cyberwill 1 Posted September 25, 2021 Author Posted September 25, 2021 thank you very much have a nice day 1
