codechurn 9 Posted September 25, 2021 Posted September 25, 2021 Does anyone have a working link for this app? I've decided to take the plunge and convert my ISOs to mkv format -- the problem is, I can't seem to get a working link to this app. The official makemkv forum thread does not seem to have a working link. Any recommendation on replacement tools?
Carlo 4561 Posted September 25, 2021 Posted September 25, 2021 Hi, try from here: https://forum.videohelp.com/threads/371886-Batch-merges-for-MKVmerge-(Windows-only)
dredd1963 17 Posted September 25, 2021 Posted September 25, 2021 Hi I've managed to download make kv OK no problems at all
codechurn 9 Posted September 26, 2021 Author Posted September 26, 2021 22 hours ago, cayars said: Hi, try from here: https://forum.videohelp.com/threads/371886-Batch-merges-for-MKVmerge-(Windows-only) That is a different program than BatchMKV. I'm looking to batch convert a bunch of DVD ISOs to MKV format.
Carlo 4561 Posted September 26, 2021 Posted September 26, 2021 The original solution you are looking doesn't seem to exist anymore. MkvBatcher - up to 16 simultaneous video conversions This might do exactly what you need but I've not used it. Worth a check.
Happy2Play 9811 Posted September 26, 2021 Posted September 26, 2021 What was wrong with BatchMKV as the it downloaded from the page just fine. What link is broken? I just used the provide link here.
codechurn 9 Posted October 1, 2021 Author Posted October 1, 2021 On 9/26/2021 at 3:34 PM, Happy2Play said: What was wrong with BatchMKV as the it downloaded from the page just fine. What link is broken? I just used the provide link here. It turns out it was not the site. I was viewing the page in Chrome and when I clicked the link to download the file, all I would see is the gradient "adaptweb" background; no file download started. I visited the page in the Edge browser and it actually downloaded the file just fine. My guess is I must have an adblock extension in my Chrome browser that is blocking the download. In any case, thanks for the help guys... now to get cracking at converting
