MrMookie74 0 Posted September 24, 2021 Posted September 24, 2021 Hi Guys As u can see in topic. Most of the time when I play a show when it comes to the end of an episode and goes to switch to the next episode emby freezes with the spinning symbol in the middle of the screen. I have to back out and play the episode manually. Doesnt happen all the time but most of the time it does. I am using Android TV version of Emby on my Nvidia Shield. I am leaning that it is more toward the server that is causing the problem and not the app itself. Could anyone enlighten me and let me know if there is a way to sort this problem out. It just started happening about 2 weeks ago. I am using the Main release of emby server and not the beta I attached my emby log from my server Thanks Mook embyserver.txt
Luke 42245 Posted September 24, 2021 Posted September 24, 2021 Hi there, can you please go over an example? Thanks.
MrMookie74 0 Posted September 24, 2021 Author Posted September 24, 2021 1 hour ago, Luke said: Hi there, can you please go over an example? Thanks. Hi Luke thanks for responding. What happens is if say I play a tv show like "Counting Cars" after the episode ends it is supposed to go to the next episode. Most of the time it doesnt do it. It just freezes like its loading the next episode but it doesnt. I have to back out to the episode selection screen then select the next episode. I just even tried upgrading to the beta thinking perhaps that might fix the problem but nope the problem still persists. Mook
ebr 16337 Posted September 24, 2021 Posted September 24, 2021 Hi. Can you tell us exactly when in that server log that happened and what was being played? Thanks.
MrMookie74 0 Posted September 29, 2021 Author Posted September 29, 2021 On 9/24/2021 at 9:46 AM, ebr said: Hi. Can you tell us exactly when in that server log that happened and what was being played? Thanks. Hey Sorry for not getting back sooner. I rebooted router and Shield TV all seems to be ok now. 1st time thats ever happened to me on the Android TV App Thanks to u and Luke for your timely responses Mook
ebr 16337 Posted September 29, 2021 Posted September 29, 2021 Okay, let us know if you run into this again.
Mookdog 90 Posted April 26, 2022 Posted April 26, 2022 (edited) Well it seems like this ugly bug reared it head again. Everytime one episode finishes and it goes to the next episode I get nothing but a spinning wheel on the screen and it doesnt go any further. I have to back out and play the episode manually. I am gonna attach my latest server log Mook Edit : Just tested both Android TV and Android app on my nvidia shield and they are both doing the same thing Edit Edit : Tested on Web UI and it worked fine. Dunno why there is the hiccup on my android device Edit Edit Edit : Had my friend test remotely on his shield using ATV and it did the same thing attached is the photo of my server the ep freezes at the end of episode 2 and wont skip to episode 3 Another Edit : Ok guys I figured it out its seems the encode I had of the show was the problem. I got another version of it and all is fine. embyserver.txt Edited April 26, 2022 by Mookdog Added update
ebr 16337 Posted April 26, 2022 Posted April 26, 2022 Glad you figured it out. The media is usually the problem in cases like this.
