Scott D 69 Posted May 13, 2023 Author Posted May 13, 2023 No need to remove the daily restart. I opened the transcode-temp folder this morning and found 3.2 gig of files from sessions that had happened in the last 24 hours. No active users at the time I checked. I would have to say that it is still happening. The scheduled restart is keeping the problem under control.
neik 874 Posted May 15, 2023 Posted May 15, 2023 On 5/13/2023 at 3:32 PM, Scott D said: No need to remove the daily restart. I opened the transcode-temp folder this morning and found 3.2 gig of files from sessions that had happened in the last 24 hours. No active users at the time I checked. I would have to say that it is still happening. The scheduled restart is keeping the problem under control. +1 Just had the same this morning with a 4.5GB file sitting there without any activity on the server. Restarted Emby and it got deleted. Doing a daily restart doesn't do any harm and can help working around this type of issuees that Emby still has.
jathe 9 Posted May 18, 2023 Posted May 18, 2023 (edited) @K22R8CT This bash does not work for me, my temp-folder had subfolder and this script only scan files in the "transcoding-temp/". My server creates a lot of subfolders like DFG456/1_1.ts and so. Can you adapt this to the actual format? Edited May 18, 2023 by jathe
K22R8CT 25 Posted May 18, 2023 Posted May 18, 2023 1 hour ago, jathe said: Can you adapt this to the actual format? I forgot I'd posted this. Right, later Emby versions use subfolders. I've updated the script (and my post) so it works: ps here's how I launch it: watch -n30 "/<PATH TO SCRIPT>/transcoding-temp-fix.sh 2>&1" > /<LOG DIRECTORY>/transcoding-temp-fix.log &
