wxg1015 9 Posted October 17, 2021 Author Posted October 17, 2021 (edited) 24 minutes ago, Luke said: Yes that title is also the file name. Works for me. a few minutes passed Edited October 17, 2021 by wxg1015
Luke 42239 Posted October 20, 2021 Posted October 20, 2021 Can you try turning off subtitles before playing? Please try that and see if it helps.
wxg1015 9 Posted October 20, 2021 Author Posted October 20, 2021 (edited) 4 hours ago, Luke said: Can you try turning off subtitles before playing? Please try that and see if it helps. The log I posted was obtained with closed captions no diferrent Edited October 20, 2021 by wxg1015
wxg1015 9 Posted November 18, 2021 Author Posted November 18, 2021 The problem has been solved. Someone has fixed the problem. End it
Luke 42239 Posted November 18, 2021 Posted November 18, 2021 7 hours ago, wxg1015 said: The problem has been solved. Someone has fixed the problem. End it Hi, who resolved it? What was the solution?
