GrimReaper 4895 Posted September 25, 2021 Posted September 25, 2021 4 minutes ago, nickysilver said: I sort of assume that last question wasn't for me. Nope, there's a quote at the beginning of the post for whom it was.
ebr 16332 Posted September 26, 2021 Posted September 26, 2021 On 9/25/2021 at 6:38 AM, GrimReaper said: Btw did that log show anything off for choppy playback Not really but it is a really old encode (xvid) which have been problematic in the past. The Shield does not have a decoder for it so the app is trying to do it in software. I imagine re-encoding to h264 would provide smooth playback.
nickysilver 16 Posted September 26, 2021 Author Posted September 26, 2021 I had converted this a while ago. It is sitting there in conversions. What I would normally have done is convert it using hand break and swapped out on the HD, then scanned the folder. But scanning fails. I had a remote session with Cayars about it, who told me, ultimately, I just have to wait for a server update. So I'm at a bit of a loss.
Carlo 4561 Posted October 1, 2021 Posted October 1, 2021 Hey @nickysilver do you know how to get to the Emby databases on the Shield? If so, could you shut down the server and copy any file starting with library and PM it to me? I'd appreciate it being able to take a look at it to see what the issue might be. Thanks, Carlo
