wondermouse 0 Posted September 20, 2021 Posted September 20, 2021 Hi, The Emby Android TV app on my Sony 4K TV always shows the lowest quality version as the default version. Changing the playback quality settings does not make any difference. Same behavior seen in the web client in Firefox, Chrome and MS Edge. The Emby Android app on my phone shows the highest quality version as default without having to make any changes to the quality settings. Not sure if this matters but I'm using this naming: <title> (year) <media>-<resolution>.<extension> E.g. Avatar (2009) Bluray-480p.mp4 Avatar (2009) Bluray-1080p.mp4 Avatar (2009) Bluray-2160p.mkv What can I do to fix this? Server: Mac mini (Mid 2011, i5, 16GB) OS: macOS 10.13 Emby Server Version 4.6.4.0 Android TV Sony KD-55XF9005 Android Version 9 Emby client Version 2.0.41g Androd Mobile Oneplus 9 Pro Android 11 Emby client Version 3.2.05
ebr 16338 Posted September 20, 2021 Posted September 20, 2021 Hi. Would all of the versions direct play?
wondermouse 0 Posted September 20, 2021 Author Posted September 20, 2021 22 minutes ago, ebr said: Hi. Would all of the versions direct play? Hi ebr, Yes, they all direct play.
ebr 16338 Posted September 20, 2021 Posted September 20, 2021 Okay, then, with the next release of the app, it will choose the highest resolution one. Right now, it is kind of undefined which one will be selected if they can all direct play.
wondermouse 0 Posted September 21, 2021 Author Posted September 21, 2021 Ok, thanks for the update. Which app though? I see this behaviour in browsers as well. Any particular version that I should keep an eye out for?
Luke 42246 Posted September 21, 2021 Posted September 21, 2021 21 minutes ago, wondermouse said: Ok, thanks for the update. Which app though? I see this behaviour in browsers as well. Any particular version that I should keep an eye out for? He's referring to the android tv/fire tv app.
