DieterC 0 Posted September 20, 2021 Posted September 20, 2021 When I start Sonarr, Emby crashes after a few minutes. I can restart Emby but after a few minutes it crashes again. The moment I stop Sonarr, Emby runs fine and remains active for days. Sonarr itself never crashes.
Carlo 4561 Posted September 20, 2021 Posted September 20, 2021 Hi, do you see anything in the server log that could be related?
DieterC 0 Posted September 20, 2021 Author Posted September 20, 2021 Emby was active again for a long time. Just launched my Sonarr and Emby crashed immediately. Restarted Emby again to view the log file. what I can see is this response time is increasing massively. And then suddenly Emby crashes. Response 200 to 192.168.1.144. Time: 77380ms. http://192.168.1.144:2222/dlna/fd7a69d0-21d3-4e4b-a19e-fd9e5ffbf09f/description.xml 2021-09-20 21:20:12.031 Debug Server: http/1.1 Response 200 to 192.168.1.144. Time: 77380ms. http://192.168.1.144:2222/dlna/fd7a69d0-21d3-4e4b-a19e-fd9e5ffbf09f/description.xml
Luke 42243 Posted September 20, 2021 Posted September 20, 2021 1 hour ago, DieterC said: Emby was active again for a long time. Just launched my Sonarr and Emby crashed immediately. Restarted Emby again to view the log file. what I can see is this response time is increasing massively. And then suddenly Emby crashes. Response 200 to 192.168.1.144. Time: 77380ms. http://192.168.1.144:2222/dlna/fd7a69d0-21d3-4e4b-a19e-fd9e5ffbf09f/description.xml 2021-09-20 21:20:12.031 Debug Server: http/1.1 Response 200 to 192.168.1.144. Time: 77380ms. http://192.168.1.144:2222/dlna/fd7a69d0-21d3-4e4b-a19e-fd9e5ffbf09f/description.xml Hit here, please attach the complete emby server log. thanks.
DieterC 0 Posted September 20, 2021 Author Posted September 20, 2021 (edited) Here you go! Info: dsm7, ds 216play latest version of Emby and Sonarr which should be compatible with dsm 7 embyserver-63767771007.txt Edited September 20, 2021 by DieterC
Happy2Play 9812 Posted September 20, 2021 Posted September 20, 2021 7 minutes ago, DieterC said: Here you go! Info: dsm7, ds 216play latest version of Emby and Sonarr which should be compatible with dsm 7 embyserver-63767771007.txt 0 B · 0 downloads Not sure what happened to your log but it empty / 0 bit.
Luke 42243 Posted September 20, 2021 Posted September 20, 2021 Hi, yes can you please upload the log file again? Thanks.
DieterC 0 Posted September 21, 2021 Author Posted September 21, 2021 Uploading a file with the iPhone doesn't seemed to be a good idea, sorry for that. Logfile attached again. embyserver-63767771007.txt
Luke 42243 Posted September 22, 2021 Posted September 22, 2021 Hi, are you still running into this? I don't see anything obvious here.
