wxg1015 9 Posted November 11, 2021 Author Posted November 11, 2021 On 10/29/2021 at 8:39 PM, quickmic said: In need a specific test case. Is there a pattern? At present, two problems have been found 1. Due to the problem of NFS encoding format, Emby.Theater cannot play the movie with the network path filled in and the name containing Chinese 2. When WebDAV is used in the network path, Blu ray movies in the form of folders cannot be played When using NFS protocol, it seems that the Chinese path needs to be encoded with UTF-8
wxg1015 9 Posted November 12, 2021 Author Posted November 12, 2021 When WebDAV is used in the network path, Blu ray movies in the form of folders cannot be played 1
Luke 42233 Posted November 12, 2021 Posted November 12, 2021 @wxg1015 I've merged your topics that are discussing the same issue. Thanks.
quickmic 1709 Posted November 16, 2021 Posted November 16, 2021 On 10/30/2021 at 7:20 AM, wxg1015 said: Sorry, the second picture is wrong. The following is the actual nfs path of this unplayable video nfs://192.168.0.10/volume1/movie/外星人保罗(加长版).2011.中英字幕£CMCT暮雨潇潇/[外星人保罗(加长版)].Paul.Extended.2011.BluRay.720p.x264.AC3-CMCT.mkv Are you using path substitution on Emby server, or were is the nfs share configured? Is the nfs share configured in Kodi as well and do you have access?
wxg1015 9 Posted November 17, 2021 Author Posted November 17, 2021 9 hours ago, quickmic said: Are you using path substitution on Emby server, or were is the nfs share configured? Is the nfs share configured in Kodi as well and do you have access? of course
wxg1015 9 Posted November 17, 2021 Author Posted November 17, 2021 10 hours ago, quickmic said: Are you using path substitution on Emby server, or were is the nfs share configured? Is the nfs share configured in Kodi as well and do you have access? The only problem that exists now is that webdav path cannot play Blu-ray movies in folder format
aiguo 0 Posted October 26, 2023 Posted October 26, 2023 楼主你好,我在emby可选共享的网络文件夹用这种格式的webdav路径(http://user:pwd@ip:端口/movie),在kodi中播放不了,你能分享一下你的设置吗
