quickmic 1709 Posted October 27, 2021 Posted October 27, 2021 What's the problem? Is the bluray not playing? Please test the same file with Kodi player/filebrowser instead using the plugin. Bluray is mostly processed by stock Kodi. If there is a problem I need to know if Kodi is the limitation.
wxg1015 9 Posted October 27, 2021 Author Posted October 27, 2021 54 minutes ago, quickmic said: What's the problem? Is the bluray not playing? Please test the same file with Kodi player/filebrowser instead using the plugin. Bluray is mostly processed by stock Kodi. If there is a problem I need to know if Kodi is the limitation. kodi Direct playback or plug-in use local mode (nfs path) can be played normally. 1
quickmic 1709 Posted October 27, 2021 Posted October 27, 2021 19 minutes ago, wxg1015 said: kodi Direct playback or plug-in use local mode (nfs path) can be played normally. Try this version: plugin.video.emby-next-gen-6.1.6-build 53 (ex4).zip
Solution wxg1015 9 Posted October 27, 2021 Author Solution Posted October 27, 2021 21 minutes ago, quickmic said: Try this version: plugin.video.emby-next-gen-6.1.6-build 53 (ex4).zip 1.3 MB · 1 download Not working properly, even mkv and iso that can be played before. Some can’t be played now
quickmic 1709 Posted October 27, 2021 Posted October 27, 2021 ok, rollback: Try this version. It should play mkv and iso but still not bluray. Please check and confirm. plugin.video.emby-next-gen-6.1.6-build 56 (ex4).zip
wxg1015 9 Posted October 27, 2021 Author Posted October 27, 2021 12 minutes ago, quickmic said: ok, rollback: Try this version. It should play mkv and iso but still not bluray. Please check and confirm. plugin.video.emby-next-gen-6.1.6-build 56 (ex4).zip 1.3 MB · 1 download still...... some ok but some error (iso、mkv) The other thing is that it doesn’t seem to be able to trigger the Blu-ray navigation, and there is even no menu selection.
quickmic 1709 Posted October 27, 2021 Posted October 27, 2021 Can you please send me a full kodi log via PM. Remove all your login data from the text file!
wxg1015 9 Posted October 27, 2021 Author Posted October 27, 2021 8 minutes ago, quickmic said: Can you please send me a full kodi log via PM. Remove all your login data from the text file! sended a message
quickmic 1709 Posted October 27, 2021 Posted October 27, 2021 Thanks, I think I see some of the problems. I'll perform some tests... What is currently not working with the last version I uploaded here? Is mkv working? Are iso working?
quickmic 1709 Posted October 27, 2021 Posted October 27, 2021 How do you load the webdav content into emby libraries? Are you using strm files or directly? I try to design a test case, no success so far
wxg1015 9 Posted October 27, 2021 Author Posted October 27, 2021 24 minutes ago, quickmic said: How do you load the webdav content into emby libraries? Are you using strm files or directly? I try to design a test case, no success so far http://webdav-user:webdav-password@ip:port/movie
quickmic 1709 Posted October 27, 2021 Posted October 27, 2021 2 minutes ago, wxg1015 said: http://webdav-user:webdav-password@ip:port/movie Yes, but that's an nfs share. I assume in this nfs share are strm files located?
wxg1015 9 Posted October 27, 2021 Author Posted October 27, 2021 11 minutes ago, quickmic said: 是的,但那是 nfs 共享。我假设在这个 nfs 共享中有 strm 文件? http://webdav-user:webdav-password@ip:port/movie this is webdav
wxg1015 9 Posted October 27, 2021 Author Posted October 27, 2021 2 minutes ago, wxg1015 said: http://webdav-user:webdav-password@ip:port/movie this is webdav 14 minutes ago, quickmic said: Yes, but that's an nfs share. I assume in this nfs share are strm files located? I think I understand what you mean. nfs, shows the normal path. example: nfs://192.168.0.10/volume1/movie/long zheng hu dou/long zheng hu dou.mkv
quickmic 1709 Posted October 27, 2021 Posted October 27, 2021 (edited) 5 minutes ago, wxg1015 said: http://webdav-user:webdav-password@ip:port/movie this is webdav yes I know, but your screenshot is a nfs share. You cannot drop a http/webdav share directly into emby servers library as a path. There must be a redirection from than nfs path to the actual webdav content. I assume the nfs share hast .strm files which does the redirection. Edited October 27, 2021 by quickmic
quickmic 1709 Posted October 27, 2021 Posted October 27, 2021 However, I think I can create a test case with strm files...
wxg1015 9 Posted October 27, 2021 Author Posted October 27, 2021 6 minutes ago, quickmic said: yes I know, but your screenshot is a nfs share. You cannot drop a http/webdav share directly into emby servers library as a path. There must be a redirection from than nfs path to the actual webdav content. I assume the nfs share hast .strm files which does the redirection. That picture, I just use it to show you where I fill in webdav. The picture below is my current settings
quickmic 1709 Posted October 27, 2021 Posted October 27, 2021 I cannot read Chinese characters. Is this the path substitution you are using?
wxg1015 9 Posted October 27, 2021 Author Posted October 27, 2021 Just now, quickmic said: I cannot read Chinese characters. Is this the path substitution you are using? yes To test webdav, must use the webdav path 1
quickmic 1709 Posted October 27, 2021 Posted October 27, 2021 (edited) Is you bluray an iso or extracted? You mentioned, it works as Kodi native content (without the plugin). I tested bluray (extracted) and it's not: Same file, Kodi native: 2021-10-27 16:00:19.854 T:9429 ERROR <general>: CFileCache::Open - <dav://USERNAME:PASSWORD@192.168.0.50:80/webdav/emby/movie1/AACS/Unit_Key_RO.inf> failed to open 2021-10-27 16:00:19.923 T:9429 ERROR <general>: CCurlFile::Open failed with code 404 for http://192.168.0.50:80/webdav/emby/movie1/BDMV/META/DL: 2021-10-27 16:00:19.923 T:9429 ERROR <general>: GetDirectory - Unable to get dav directory (dav://USERNAME:PASSWORD@192.168.0.50:80/webdav/emby/movie1/BDMV/META/DL) 2021-10-27 16:00:19.923 T:9429 ERROR <general>: GetDirectory - Error getting dav://USERNAME:PASSWORD@192.168.0.50:80/webdav/emby/movie1/BDMV/META/DL 2021-10-27 16:00:19.963 T:9429 ERROR <general>: CCurlFile::Open failed with code 404 for http://192.168.0.50:80/webdav/emby/movie1/BDMV/BACKUP/PLAYLIST/PLAYLIST: 2021-10-27 16:00:19.963 T:9429 ERROR <general>: CFileCache::Open - <dav://USERNAME:PASSWORD@192.168.0.50:80/webdav/emby/movie1/BDMV/BACKUP/PLAYLIST/PLAYLIST> failed to open 2021-10-27 16:00:20.085 T:9429 WARNING <general>: CFileCache::Seek - <dav://USERNAME:PASSWORD@192.168.0.50:80/webdav/emby/movie1/BDMV/CLIPINF/00000.clpi> failed to get remaining data 2021-10-27 16:00:20.093 T:9429 WARNING <general>: CFileCache::Seek - <dav://USERNAME:PASSWORD@192.168.0.50:80/webdav/emby/movie1/BDMV/BACKUP/CLIPINF/00000.clpi> failed to get remaining data 2021-10-27 16:00:21.495 T:9094 INFO <general>: VideoPlayer::OpenFile: bluray://dav%3a%2f%2f192.168.0.50%3a80%2fwebdav%2femby%2fmovie1%2f/BDMV/PLAYLIST/00000.mpls 2021-10-27 16:00:21.495 T:9441 INFO <general>: Creating InputStream 2021-10-27 16:00:21.547 T:9120 INFO <general>: INFO: EMBY.hooks.player.Player: [ onPlayBackStarted ] 2021-10-27 16:00:21.612 T:9441 ERROR <general>: CCurlFile::Open failed with code 404 for http://192.168.0.50:80/webdav/emby/movie1/AACS/Unit_Key_RO.inf: 2021-10-27 16:00:21.612 T:9441 ERROR <general>: CFileCache::Open - <dav://USERNAME:PASSWORD@192.168.0.50:80/webdav/emby/movie1/AACS/Unit_Key_RO.inf> failed to open 2021-10-27 16:00:21.680 T:9441 ERROR <general>: CCurlFile::Open failed with code 404 for http://192.168.0.50:80/webdav/emby/movie1/BDMV/META/DL: 2021-10-27 16:00:21.680 T:9441 ERROR <general>: GetDirectory - Unable to get dav directory (dav://USERNAME:PASSWORD@192.168.0.50:80/webdav/emby/movie1/BDMV/META/DL) 2021-10-27 16:00:21.680 T:9441 ERROR <general>: GetDirectory - Error getting dav://USERNAME:PASSWORD@192.168.0.50:80/webdav/emby/movie1/BDMV/META/DL 2021-10-27 16:00:21.753 T:9441 WARNING <general>: CFileCache::Seek - <dav://USERNAME:PASSWORD@192.168.0.50:80/webdav/emby/movie1/BDMV/CLIPINF/00000.clpi> failed to get remaining data 2021-10-27 16:00:22.816 T:9441 WARNING <general>: CFileCache::Seek - <dav://USERNAME:PASSWORD@192.168.0.50:80/webdav/emby/movie1/BDMV/BACKUP/CLIPINF/00000.clpi> failed to get remaining data 2021-10-27 16:00:24.003 T:9441 WARNING <general>: CFileCache::Seek - <dav://USERNAME:PASSWORD@192.168.0.50:80/webdav/emby/movie1/BDMV/CLIPINF/00000.clpi> failed to get remaining data 2021-10-27 16:00:24.015 T:9441 WARNING <general>: CFileCache::Seek - <dav://USERNAME:PASSWORD@192.168.0.50:80/webdav/emby/movie1/BDMV/BACKUP/CLIPINF/00000.clpi> failed to get remaining data 2021-10-27 16:00:24.153 T:9441 WARNING <general>: CFileCache::Seek - <dav://USERNAME:PASSWORD@192.168.0.50:80/webdav/emby/movie1/BDMV/CLIPINF/00000.clpi> failed to get remaining data 2021-10-27 16:00:24.181 T:9441 WARNING <general>: CFileCache::Seek - <dav://USERNAME:PASSWORD@192.168.0.50:80/webdav/emby/movie1/BDMV/BACKUP/CLIPINF/00000.clpi> failed to get remaining data 2021-10-27 16:00:24.252 T:9441 WARNING <general>: CFileCache::Seek - <dav://USERNAME:PASSWORD@192.168.0.50:80/webdav/emby/movie1/BDMV/CLIPINF/00000.clpi> failed to get remaining data 2021-10-27 16:00:24.276 T:9441 WARNING <general>: CFileCache::Seek - <dav://USERNAME:PASSWORD@192.168.0.50:80/webdav/emby/movie1/BDMV/BACKUP/CLIPINF/00000.clpi> failed to get remaining data 2021-10-27 16:00:24.290 T:9441 INFO <general>: VideoPlayer: playing a file with menu's 2021-10-27 16:00:24.290 T:9441 INFO <general>: Creating Demuxer 2021-10-27 16:00:24.291 T:9441 ERROR <general>: Open - error probing input format, bluray://dav%3a%2f%2f192.168.0.50%3a80%2fwebdav%2femby%2fmovie1%2f/BDMV/PLAYLIST/00000.mpls 2021-10-27 16:00:24.291 T:9441 ERROR <general>: OpenDemuxStream - Error creating demuxer With plugin and path substitution: 2021-10-27 16:00:14.939 T:9400 ERROR <general>: CCurlFile::Open failed with code 404 for http://192.168.0.50/webdav/emby/movie1/AACS/Unit_Key_RO.inf: 2021-10-27 16:00:14.939 T:9400 ERROR <general>: CFileCache::Open - <http://USERNAME:PASSWORD@192.168.0.50/webdav/emby/movie1/AACS/Unit_Key_RO.inf> failed to open 2021-10-27 16:00:15.009 T:9400 ERROR <general>: CCurlFile::Open failed with code 404 for http://192.168.0.50/webdav/emby/movie1/BDMV/META/DL: 2021-10-27 16:00:15.009 T:9400 ERROR <general>: GetDirectory - Unable to get http directory (http://USERNAME:PASSWORD@192.168.0.50/webdav/emby/movie1/BDMV/META/DL) 2021-10-27 16:00:15.009 T:9400 ERROR <general>: GetDirectory - Error getting http://USERNAME:PASSWORD@192.168.0.50/webdav/emby/movie1/BDMV/META/DL 2021-10-27 16:00:15.020 T:9400 ERROR <general>: CCurlFile::Open failed with code 404 for http://192.168.0.50/webdav/emby/movie1/disc.inf: 2021-10-27 16:00:15.020 T:9400 ERROR <general>: CFileCache::Open - <http://USERNAME:PASSWORD@192.168.0.50/webdav/emby/movie1/disc.inf> failed to open 2021-10-27 16:00:15.165 T:9400 WARNING <general>: CFileCache::Seek - <http://USERNAME:PASSWORD@192.168.0.50/webdav/emby/movie1/BDMV/CLIPINF/00000.clpi> failed to get remaining data 2021-10-27 16:00:15.177 T:9400 WARNING <general>: CFileCache::Seek - <http://USERNAME:PASSWORD@192.168.0.50/webdav/emby/movie1/BDMV/BACKUP/CLIPINF/00000.clpi> failed to get remaining data 2021-10-27 16:00:16.727 T:9094 INFO <general>: VideoPlayer::OpenFile: bluray://http%3a%2f%2f192.168.0.50%2fwebdav%2femby%2fmovie1%2f/BDMV/PLAYLIST/00000.mpls 2021-10-27 16:00:16.727 T:9410 INFO <general>: Creating InputStream 2021-10-27 16:00:16.786 T:9410 ERROR <general>: CCurlFile::Open failed with code 404 for http://192.168.0.50/webdav/emby/movie1/AACS/Unit_Key_RO.inf: 2021-10-27 16:00:16.786 T:9410 ERROR <general>: CFileCache::Open - <http://USERNAME:PASSWORD@192.168.0.50/webdav/emby/movie1/AACS/Unit_Key_RO.inf> failed to open 2021-10-27 16:00:16.840 T:9120 INFO <general>: INFO: EMBY.hooks.player.Player: [ onPlayBackStarted ] 2021-10-27 16:00:16.848 T:9410 ERROR <general>: CCurlFile::Open failed with code 404 for http://192.168.0.50/webdav/emby/movie1/BDMV/META/DL: 2021-10-27 16:00:16.848 T:9410 ERROR <general>: GetDirectory - Unable to get http directory (http://USERNAME:PASSWORD@192.168.0.50/webdav/emby/movie1/BDMV/META/DL) 2021-10-27 16:00:16.848 T:9410 ERROR <general>: GetDirectory - Error getting http://USERNAME:PASSWORD@192.168.0.50/webdav/emby/movie1/BDMV/META/DL 2021-10-27 16:00:16.915 T:9410 WARNING <general>: CFileCache::Seek - <http://USERNAME:PASSWORD@192.168.0.50/webdav/emby/movie1/BDMV/CLIPINF/00000.clpi> failed to get remaining data 2021-10-27 16:00:16.924 T:9410 WARNING <general>: CFileCache::Seek - <http://USERNAME:PASSWORD@192.168.0.50/webdav/emby/movie1/BDMV/BACKUP/CLIPINF/00000.clpi> failed to get remaining data 2021-10-27 16:00:16.991 T:9410 WARNING <general>: CFileCache::Seek - <http://USERNAME:PASSWORD@192.168.0.50/webdav/emby/movie1/BDMV/CLIPINF/00000.clpi> failed to get remaining data 2021-10-27 16:00:17.008 T:9410 WARNING <general>: CFileCache::Seek - <http://USERNAME:PASSWORD@192.168.0.50/webdav/emby/movie1/BDMV/BACKUP/CLIPINF/00000.clpi> failed to get remaining data 2021-10-27 16:00:17.102 T:9410 WARNING <general>: CFileCache::Seek - <http://USERNAME:PASSWORD@192.168.0.50/webdav/emby/movie1/BDMV/CLIPINF/00000.clpi> failed to get remaining data 2021-10-27 16:00:17.121 T:9410 WARNING <general>: CFileCache::Seek - <http://USERNAME:PASSWORD@192.168.0.50/webdav/emby/movie1/BDMV/BACKUP/CLIPINF/00000.clpi> failed to get remaining data 2021-10-27 16:00:17.197 T:9410 WARNING <general>: CFileCache::Seek - <http://USERNAME:PASSWORD@192.168.0.50/webdav/emby/movie1/BDMV/CLIPINF/00000.clpi> failed to get remaining data 2021-10-27 16:00:17.223 T:9410 WARNING <general>: CFileCache::Seek - <http://USERNAME:PASSWORD@192.168.0.50/webdav/emby/movie1/BDMV/BACKUP/CLIPINF/00000.clpi> failed to get remaining data 2021-10-27 16:00:17.246 T:9410 INFO <general>: VideoPlayer: playing a file with menu's 2021-10-27 16:00:17.246 T:9410 INFO <general>: Creating Demuxer 2021-10-27 16:00:17.248 T:9410 ERROR <general>: Open - error probing input format, bluray://http%3a%2f%2f192.168.0.50%2fwebdav%2femby%2fmovie1%2f/BDMV/PLAYLIST/00000.mpls I need exact instruction, how you access the data on Emby server. Also in my setup, there are no invalid paths as in your screenshot -> no spaces in the urls as in yours. And we are still talking about next-gen in native mode, correct? Edited October 27, 2021 by quickmic
quickmic 1709 Posted October 27, 2021 Posted October 27, 2021 Same file with native file access, Kodi native no plugin: 2021-10-27 16:14:27.778 T:10759 ERROR <general>: GetDirectory - Error getting /mnt/storage2/emby-test/webdav/movie1/BDMV/META/DL 2021-10-27 16:14:29.158 T:9094 INFO <general>: VideoPlayer::OpenFile: bluray://%2fmnt%2fstorage2%2femby-test%2fwebdav%2fmovie1%2f/BDMV/PLAYLIST/00000.mpls 2021-10-27 16:14:29.158 T:10763 INFO <general>: Creating InputStream 2021-10-27 16:14:29.166 T:10763 ERROR <general>: GetDirectory - Error getting /mnt/storage2/emby-test/webdav/movie1/BDMV/META/DL 2021-10-27 16:14:29.168 T:10763 INFO <general>: VideoPlayer: playing a file with menu's 2021-10-27 16:14:29.168 T:10763 INFO <general>: Creating Demuxer 2021-10-27 16:14:29.186 T:10763 INFO <general>: Opening stream: 0 source: 256 2021-10-27 16:14:29.186 T:10763 INFO <general>: Creating video codec with codec id: 2 2021-10-27 16:14:29.186 T:10763 INFO <general>: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-2 video 2021-10-27 16:14:29.186 T:10763 INFO <general>: Creating video thread 2021-10-27 16:14:29.186 T:10765 INFO <general>: running thread: video_thread 2021-10-27 16:14:29.186 T:10763 INFO <general>: Opening stream: 1 source: 256 2021-10-27 16:14:29.186 T:10763 INFO <general>: Finding audio codec for: 86019 2021-10-27 16:14:29.187 T:10763 INFO <general>: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder ac3 2021-10-27 16:14:29.187 T:10763 INFO <general>: Creating audio thread 2021-10-27 16:14:29.187 T:10766 INFO <general>: running thread: CVideoPlayerAudio::Process() 2021-10-27 16:14:29.187 T:10765 INFO <general>: VDPAU::CreateContext - creating decoder context 2021-10-27 16:14:29.199 T:10766 INFO <general>: Creating audio stream (codec id: 86019, channels: 2, sample rate: 48000, no pass-through) 2021-10-27 16:14:29.199 T:9103 INFO <general>: CActiveAESink::OpenSink - initialize sink 2021-10-27 16:14:29.217 T:10765 INFO <general>: vdp_device = 0x00000001 vdp_st = 0x0 2021-10-27 16:14:29.217 T:10765 INFO <general>: VDPAU Decoder capabilities: 2021-10-27 16:14:29.217 T:10765 INFO <general>: name level macbs width height 2021-10-27 16:14:29.217 T:10765 INFO <general>: ------------------------------------ 2021-10-27 16:14:29.217 T:10765 INFO <general>: MPEG1 0 65536 4096 4096 2021-10-27 16:14:29.217 T:10765 INFO <general>: MPEG2_SIMPLE 3 65536 4096 4096 2021-10-27 16:14:29.217 T:10765 INFO <general>: MPEG2_MAIN 3 65536 4096 4096 2021-10-27 16:14:29.217 T:10765 INFO <general>: H264_BASELINE 51 65536 4096 4096 2021-10-27 16:14:29.217 T:10765 INFO <general>: H264_MAIN 51 65536 4096 4096 2021-10-27 16:14:29.217 T:10765 INFO <general>: H264_HIGH 51 65536 4096 4096 2021-10-27 16:14:29.217 T:10765 INFO <general>: VC1_SIMPLE 1 8190 2048 2048 2021-10-27 16:14:29.217 T:10765 INFO <general>: VC1_MAIN 2 8190 2048 2048 2021-10-27 16:14:29.217 T:10765 INFO <general>: VC1_ADVANCED 4 8190 2048 2048 2021-10-27 16:14:29.217 T:10765 INFO <general>: MPEG4_PART2_ASP 5 8192 2048 2048 2021-10-27 16:14:29.217 T:10765 INFO <general>: HEVC_MAIN 153 262144 8192 8192 2021-10-27 16:14:29.217 T:10765 INFO <general>: VP9_PROFILE_0 1 262144 8192 8192
wxg1015 9 Posted October 27, 2021 Author Posted October 27, 2021 4 minutes ago, quickmic said: 你是蓝光iso还是提取的? 你提到过,它可以作为 Kodi 原生内容(没有插件)。 我测试了蓝光(提取),但不是: 相同的文件,Kodi 本机: 使用插件和路径替换: 我需要确切的说明,如何访问 Emby 服务器上的数据。同样在我的设置中,您的屏幕截图中没有无效路径 -> 网址中没有空格。 我们仍在谈论本机模式下的下一代,对吗? yes It's okay in the case of nfs. I haven't tested webdav under kodi. Later, I will test kodi to play webdav directly. You mean maybe kodi itself can't play bdmv? But according to the plug-in you modified for the first time, the ones without spaces (bdmv) can be played, and the only problematic ones are bdmv with spaces.
quickmic 1709 Posted October 27, 2021 Posted October 27, 2021 (edited) 12 minutes ago, wxg1015 said: yes It's okay in the case of nfs. I haven't tested webdav under kodi. Later, I will test kodi to play webdav directly. You mean maybe kodi itself can't play bdmv? But according to the plug-in you modified for the first time, the ones without spaces (bdmv) can be played, and the only problematic ones are bdmv with spaces. General info for webdav in Kodi: Yes, because mkv, iso etc. don't need subfolder access. The plugin can inject correct main folders in Kodi's database but not subfolders. Extracted bluray: Kodi starts browsing in the subfolders of the bluray and build the paths internally (not the plugin). Seems Kodi is not respecting passwords. here: Open - error probing input format, bluray://dav%3a%2f%2f192.168.0.50%3a80%2fwebdav%2femby%2fmovie1%2f/BDMV/PLAYLIST/00000.mpls I guess that's the problem but as mentioned. Kodi itself build that subpath, not the plugin. Spaces in URL: I have no idea, why you still have spaces in the URL. I have non and I think I used the same approach as you did. Anyway, please test webdav in Kodi directly. If this is not working (what I'm assuming) we can stop here. But iso (no matter if DVD or Bluray should (theoretically) work. Edited October 27, 2021 by quickmic
wxg1015 9 Posted October 27, 2021 Author Posted October 27, 2021 (edited) 5 minutes ago, quickmic said: General info for webdav in Kodi: Yes, because mkv, iso etc. don't need subfolder access. The plugin can inject correct main folders in Kodi's database but not subfolders. Extracted bluray: Kodi starts browsing in the subfolders of the bluray and build the paths internally (not the plugin). Seems Kodi is not respecting passwords. here: Open - error probing input format, bluray://dav%3a%2f%2f192.168.0.50%3a80%2fwebdav%2femby%2fmovie1%2f/BDMV/PLAYLIST/00000.mpls I guess that's the problem but as mentioned. Kodi itself build that subpath, not the plugin. Spaces in URL: I have no idea, why you still have spaces in the URL. I have non and I think I used the same approach as you did. Anyway, please test webdav in Kodi directly. If this is not working (what I'm assuming) we can stop here. But iso (no matter if DVD or Bluray should (theoretically) work. If kodi directly adds webdav, everything is normal. Even the Blu-ray navigation menu is normal. Regardless of whether there are spaces in the path. So the problem should not be with kodi Edited October 27, 2021 by wxg1015
quickmic 1709 Posted October 27, 2021 Posted October 27, 2021 Just now, wxg1015 said: If kodi directly adds webdav, everything is normal. Even the Blu-ray navigation menu is normal. Regardless of whether there are spaces in the path. So the problem should not be with kodi What you posted is FTP not webdav. ALL fileshares will work, but webdav is something different.
