vector991 0 Posted September 19, 2021 Posted September 19, 2021 I am having two problems with the addon syncing (not EmbyCon): 1. I have a show that is split into 2 paths, one path for season 1 and one for season 2. It's fine. Then I go to move season 2 to where season 1 is, and I remove the now empty show directory where season 2 was. This causes a problem where the entire show is no longer present in Kodi after the sync. Refreshing metadata from context menu doesn't fix. 2. On a similar syncing problem where a show is split into 2 directories, if I add a new episode to a season, the show then appears unmerged in Kodi as two separate shows. I ensure the naming is consistent. It doesn't happen all the time, just occasionally and I can't really predict when it will happen. Both issues have been occurring unpredictably from v5.3.1 to 6.0.9 (build 55). I'm running Emby server on Linux. The metadata is all fine, so I know it's on the addon/Kodi side.
quickmic 1709 Posted September 20, 2021 Posted September 20, 2021 I'll check that, maybe I can improve something.
