Speedytag 1 Posted September 18, 2021 Posted September 18, 2021 I have tried to install a new provider using this M3U I've amended the login and password for security. It failed to save. I have tried multiple times. I'm hoping this part of the log might help. 2021-09-18 18:27:52.554 Info HttpClient: GET http://line.liveott.ru/get.php?username=XXXXXXX&password=XXXXXXXX 2021-09-18 18:27:53.508 Error Server: Error processing request *** Error Report *** Version: 4.6.4.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -updatepackage emby-server-synology7_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.180+ (root@build15) (gcc version 7.5.0 (GCC) ) #41890 SMP Thu Jul 15 03:43:42 CST 2021 Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: NotFound at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.LiveTV.TunerHosts.M3UTunerHost.Validate(TunerHostInfo info) at Emby.LiveTV.LiveTvManager.SaveTunerHost(TunerHostInfo info, CancellationToken cancellationToken) at MediaBrowser.LiveTV.Api.LiveTvService.Post(AddTunerHost request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext()
Carlo 4561 Posted September 18, 2021 Posted September 18, 2021 Hi, that error appears to be telling you the URL entered isn't valid as it couldn't find it. Have you tried loading the URL in a browser to verify it's valid? It's possible this could work in a browser but not in Emby and that would be because the provider is blocking the request based on the user agent being sent. You can adjust this as needed in the m3u setup of the tuner.
martyboy26 0 Posted September 18, 2021 Posted September 18, 2021 Yes, irs valid as it works in other apps, just not Emby. Can I change any settings at this end?
ebr 16336 Posted September 18, 2021 Posted September 18, 2021 Just now, martyboy26 said: Yes, irs valid as it works in other apps, just not Emby If you put that exact url in a browser address bar, you get back proper XML?
martyboy26 0 Posted September 18, 2021 Posted September 18, 2021 It seems to be OK. I can load it into IPTV Smarters and it works fine.
ebr 16336 Posted September 18, 2021 Posted September 18, 2021 The provider may be looking for a specific user agent. Have you tried modifying that in the Emby settings?
martyboy26 0 Posted September 18, 2021 Posted September 18, 2021 Sorry, I’m a bit of a newbie. What do I input in the user agent section?
Carlo 4561 Posted September 18, 2021 Posted September 18, 2021 Well first we need you to try putting the URL in a web browser like Chrome to see if that returns the file.
martyboy26 0 Posted September 18, 2021 Posted September 18, 2021 7 minutes ago, martyboy26 said: That’s what I got when I typed in the xml address for the EPG
martyboy26 0 Posted September 18, 2021 Posted September 18, 2021 Would you be able to check it if I sent you the complete URL to somewhere private?
Carlo 4561 Posted September 18, 2021 Posted September 18, 2021 Sure send me a PM and I'd be happy to test this on my test server.
Carlo 4561 Posted September 18, 2021 Posted September 18, 2021 This looks like more an issue with it timing out then a user agent issue. The m3u file has more than 800K lines in it and full of VOD & 24/7 channels. What you want to do with a list like this is setup xTeVe https://github.com/xteve-project/xTeVe Setup xTeVe to read in the m3u & XML files then apply filters to remove the 24/7 and VOD channels. Then apply filters to narrow down the list to only countries that are needed. You can then narrow those down as well to get a good assortment of channels you will actually use that have guide data. xTeVe will give you a new URLs to use that you would enter in Emby. This will only contain the filtered channels and should load at that point in Emby Server.
