Luke 42242 Posted June 9, 2022 Posted June 9, 2022 Hi, does it support m3u output,? If yes then you can import that into emby server.
kanipek 230 Posted June 10, 2022 Posted June 10, 2022 On 6/8/2022 at 4:13 PM, meganitro said: Any solution for pluto tv on emby? Check this out: https://community.getchannels.com/t/pluto-for-channels/24870/458 There is a docker solution and a non docker solution. For me it works well.
multizip 0 Posted October 4, 2022 Posted October 4, 2022 jkramer Thanks for the help, it's working fine here. But I'm Brazilian, the channels are in Spanish and English. Can't I get a list of channels in Brazil? Here's the pluto tv www.pluto.tv but I wanted to integrate in emby
jkramer 12 Posted October 4, 2022 Posted October 4, 2022 Is it in your language when you access it from your location on www.pluto.tv? If not, I don't see how accessing it via Pluto's API will improve upon that.
multizip 0 Posted October 4, 2022 Posted October 4, 2022 yes, the link below when I open it is already in Portuguese www.pluto.tv but the list is not it works very well, but it doesn't have any channel in portuguese
meganitro 10 Posted November 1, 2022 Posted November 1, 2022 no pluto tv tem uma lista m3u8 que funciona bem no xciptv pois identifica como samsung tv mas no emby quando chega nos comerciais, trava e não funciona a não ser que saia, espere passar os comerciais e volte. já tentei de tudo, inclusive utilizei o xteve e mesmo assim trava. alguma solução?
