HarryMuscle 3 Posted September 15, 2021 Posted September 15, 2021 (edited) I tried searching by haven't found an actual definitive answer ... is hardware transcoding and tone mapping possible when running Emby inside a Docker container on an Intel Celeron based Synology NAS (in my case it would be a DS1520+)? Is it just a matter of passing in /dev/dri? Also, assuming that's all there's to it, should I use QuickSync or VA API? Thanks, Harry Edited September 15, 2021 by HarryMuscle
Carlo 4561 Posted September 15, 2021 Posted September 15, 2021 I've got the 920+ which is very similar with the Celeron CPU and I prefer QuickSync. My box easily transcode this well as do HDR->SDR tone mapping. I'm not running under Docker as I choose to use the native Emby Synology app so I can't comment on any performance differences. Any reason you aren't running the native Synology Emby app vs docker?
