Nav2021 1 Posted September 13, 2021 Posted September 13, 2021 Hi Guys where can i download the latest version of Emby for Samsung Smart TV in Australia please?
Luke 42241 Posted September 14, 2021 Posted September 14, 2021 https://emby.media/emby-for-samsung-smart-tv.html Please let us know if this helps. Thanks.
Nav2021 1 Posted September 14, 2021 Author Posted September 14, 2021 Thank you when was this version released?
FrostByte 5453 Posted September 14, 2021 Posted September 14, 2021 (edited) If you navigate up to the folder level where the download link is by removing the filename you can see the exact date Luke uploaded the file Emby.Releases/tizen at master · MediaBrowser/Emby.Releases · GitHub So ~5 hours ago as of right now Edit: and if you want you can follow the release notes pinned post then you should get a notification depending on your forum settings Edited September 14, 2021 by FrostByte 1
Nav2021 1 Posted September 22, 2021 Author Posted September 22, 2021 Hi guys thanks for your help. But im having problems in trying to install the app. The old version of the app had expired so i have removed it, power cycled the TV, downloaded the app on a FAT16 USB drive, but the TV sees the USB drive but will not start install and it won't see the files in the userwidget folder either. please help
Solution FrostByte 5453 Posted September 23, 2021 Solution Posted September 23, 2021 59 minutes ago, Nav2021 said: Hi guys thanks for your help. But im having problems in trying to install the app. The old version of the app had expired so i have removed it, power cycled the TV, downloaded the app on a FAT16 USB drive, but the TV sees the USB drive but will not start install and it won't see the files in the userwidget folder either. please help When you say "remove" do you mean you clicked "Remove" from the Home? Because you need to go to app settings up in the upper right corner by clicking the cog wheel and "Delete" the old Emby version. Anyhow, the symptoms you describe are exactly what happens when an old version is installed.
