Florian2000 17 Posted September 13, 2021 Posted September 13, 2021 (edited) Hi, I often see that Amazon / Netflix and Co. do change the episode composition. Meaning: Amazon: they combine 3 Episodes (each ~ 4-5mins) to one combined Episode with ~ 13min Netflix: they combine 4 Episodes to one combined Episode with ~ 18min The downside of this combining of episodes is that the Episodes get wrong texts from the IMDb etc.. Instead of manually cut the combined episodes it woulde be nice to have a textfile for the "missing" episode and within this textfile a reference point which file should be played and from which minutes/seconds on. e.g. the original video files Peppa Wutz_S01E01_Matschepampe! - Sausia ist weg! - Beste Freunde - Polly Piepmatz (DE-EN).mkv Peppa Wutz_S01E05_Verstecken - Im Kindergarten - Mama Wutz muss arbeiten - Schweinchen in der Mitte (DE-EN).mkv the info files: Peppa Wutz_S01E02_Sausia ist weg.nfo and within the textfile there is the reference file and a timestamp: "Peppa Wutz_S01E01_Matschepampe! - Sausia ist weg! - Beste Freunde - Polly Piepmatz (DE-EN).mkv 00:04:46" <-- hh:mm:ss Does this make sense? or is it easier to just cut the files? Or are there other solutions to overcome this problem? Thank you! Br, Florian Edited September 13, 2021 by Florian2000
Florian2000 17 Posted September 13, 2021 Author Posted September 13, 2021 7 hours ago, Florian2000 said: Instead of manually cut well, I just realized how easy it is to cut the files with MKVToolNix...so I would think the feature request is obsolete now. in this example one combined file is divided into 4 parts based on their timestamps...then the multiplexing is started and quite fast finished... 1
Happy2Play 9814 Posted September 13, 2021 Posted September 13, 2021 7 hours ago, Florian2000 said: Peppa Wutz_S01E01_Matschepampe! - Sausia ist weg! - Beste Freunde - Polly Piepmatz (DE-EN).mkv Peppa Wutz_S01E05_Verstecken - Im Kindergarten - Mama Wutz muss arbeiten - Schweinchen in der Mitte (DE-EN).mkv But since these are actually sequential episodes per TVDB you could just name them like this S01E01-E4. and S01E05-E8. Now if they were none sequential episode like most toons are then splitting them would be required 2
Florian2000 17 Posted September 14, 2021 Author Posted September 14, 2021 (edited) 12 hours ago, Happy2Play said: But since these are actually sequential episodes per TVDB you could just name them like this S01E01-E4. and S01E05-E8. hmm, doesn't work the way I would expect it because the nameing with S01E17-20 / S01E17-E20 leads to only one entry in the episode guide which is not wanted. Each entry should be visible for it's one. And in the best case each separate entry would jump to the right timestamp. I think it would be better if it is displayed at least separated (down below is the listing when the files are splitted): feature requests: 1) the separation of titles should be configurable e.g. | instead of , only. 2) And also the text for the episodes should be not in one large block...otherwise it's hard to distinguish... 3) timestamps to jump directly to the correct episodes should be possible. so it is a way...but I think the manual splitting is in the end more comfortable and enjoyable because of the mentioned downsides (only one picture for 4 episodes / separation of title not so easy to distinguish / text also not easy to distinguish / and the biggest issue would be that only the first episode of the combined file can be started directly - the others not / the already watched counter is also not correct possible ) In my specific use-case, I will stick with MKVToolNix because it is really pretty easy to split the episodes. And I have to use it anyway because I have to merge the audio languages DE/EN and subtitles, too. Edited September 14, 2021 by Florian2000
ebr 16339 Posted September 14, 2021 Posted September 14, 2021 4 hours ago, Florian2000 said: timestamps to jump directly to the correct episodes should be possible If the item contains chapters that are correct for this then this is already there. Otherwise, I have no idea how we'd know where these time points are. For what you want, splitting them is the best course of action. 1
Florian2000 17 Posted September 18, 2021 Author Posted September 18, 2021 (edited) On 9/14/2021 at 2:17 PM, ebr said: If the item contains chapters that are correct for this then this is already there. if I open *.mkv files with chapters with VLC, I can jump directly to the chapters. in this pictures you can see 9 chapters. Works pretty fine. if I put the exact same file in the emby library... it get's one picture (01_Forever_Young)...the other ones are other files. if I play the file "01_Forever_Young" (mkv-file) it is not possible to jump to the existing chapters... Why is that? Am I doing something wrong? Or does this functionality not exist in emby? Br, Florian Edited September 18, 2021 by Florian2000
ebr 16339 Posted September 18, 2021 Posted September 18, 2021 If you go to the detail screen of that item (click on it in that image) you should get chapters on that screen. 1
Solution Luke 42246 Posted September 18, 2021 Solution Posted September 18, 2021 4 hours ago, ebr said: If you go to the detail screen of that item (click on it in that image) you should get chapters on that screen. Assuming video preview thumbnail extraction is enabled. 1
Florian2000 17 Posted September 19, 2021 Author Posted September 19, 2021 18 hours ago, Luke said: Assuming video preview thumbnail extraction is enabled. this was the missing part! Thx!
Florian2000 17 Posted September 19, 2021 Author Posted September 19, 2021 is it somehow possible to rename the chapters?
Florian2000 17 Posted September 19, 2021 Author Posted September 19, 2021 and last but not least: is it possible to jump to the next chapter? because currently there are only the symbols for 10sec back and forward but how can I jump to the next or previous chapter from this menu? is this configurable?
Happy2Play 9814 Posted September 19, 2021 Posted September 19, 2021 15 minutes ago, Florian2000 said: and last but not least: is it possible to jump to the next chapter? because currently there are only the symbols for 10sec back and forward but how can I jump to the next or previous chapter from this menu? is this configurable? Currently no there is no chapter option in the OSD (not positive if applies to all clients), in the next release 4.7 you will have a OSD menu option to show chapters. 1
Happy2Play 9814 Posted September 19, 2021 Posted September 19, 2021 1 hour ago, Florian2000 said: is it somehow possible to rename the chapters? Emby auto generated chapters no, but files with chapter files yes in mkvtoolnix chapter editor. 1
Florian2000 17 Posted September 20, 2021 Author Posted September 20, 2021 thx! exactly what I needed! Chapter Renaming via MKVToolNix is easy.
Florian2000 17 Posted September 20, 2021 Author Posted September 20, 2021 the proof for the re-naming of the chapters via MKVToolNix works pretty well: the result within Emby Web-Client: the re-naming via MKVToolNix: and finally save the new chapter names with <Strg-S> Thanks for the two hints: 1) emby does support chapter thumbnails when the video thumbnails are set for the library 2) renaming of the chapters is possible via MKVToolNix "chapter-editor" no need for multiplexing...just saving. Br, Florian
Florian2000 17 Posted September 21, 2021 Author Posted September 21, 2021 On 9/19/2021 at 9:00 PM, Happy2Play said: Currently no there is no chapter option in the OSD (not positive if applies to all clients), in the next release 4.7 you will have a OSD menu option to show chapters. does this mean for the Web-Client or/and for the Fire-TV Client, too? Br, Florian
ebr 16339 Posted September 21, 2021 Posted September 21, 2021 34 minutes ago, Florian2000 said: or/and for the Fire-TV Client, too Hi. The Fire TV app already has in playback access to chapters. 1
Florian2000 17 Posted September 21, 2021 Author Posted September 21, 2021 4 hours ago, ebr said: Hi. The Fire TV app already has in playback access to chapters. Thanks for the hint! Maybe I was confused...when pressing the down button on the remote, I see this: and I thought that the chapter jumping would be realized with this kind of buttons but now I realize there are two possible ways. Either pressing this button: or when the movie is playing just press the up button and the chapters are listed with thumbnail previews. but what is this button for? I just get a kind of EPG with no data. I see no real sense of it while playing movie files. Also I do miss these kind of standard buttons in the menu when pressing the button just down on the remote....although there is a very nice chapter selection available when pressing the button up on the remote. Br, Florian
Happy2Play 9814 Posted September 21, 2021 Posted September 21, 2021 (edited) 2 hours ago, Florian2000 said: Also I do miss these kind of standard buttons in the menu when pressing the button just down on the remote Well that is the controversy of that button does it mean next chapter or next item? From a Series stand point that button takes you to the next item. Edited September 21, 2021 by Happy2Play
ebr 16339 Posted September 21, 2021 Posted September 21, 2021 2 hours ago, Florian2000 said: I just get a kind of EPG with no data Hi. Do you have live TV setup but with no guide data?
Florian2000 17 Posted September 21, 2021 Author Posted September 21, 2021 13 minutes ago, ebr said: Do you have live TV setup but with no guide data? yes, currently this is the case. I just started playing with LiveTV around a couple of weeks but didn't get to manage the epg stuff in time. it wasn't that important for me at the moment. but anyway...why is this function here? is it for fast switching from watching a movie I already have in the library to LiveTV?
ebr 16339 Posted September 21, 2021 Posted September 21, 2021 19 minutes ago, Florian2000 said: why is this function here? is it for fast switching from watching a movie I already have in the library to LiveTV? Yes or maybe you see an ad (if you're watching a recording) for a show coming up and you want to quickly set it up to record.
