thurwill 1 Posted September 11, 2021 Posted September 11, 2021 I am extremely new to Emby, as in less than a week. I've been a Plex user for about 5 years or so, and for the most part have liked it. For the last year or so, I am starting 'not' to like it very much, due to reasons I won't even go into here, which prompted me to start looking elsewhere. After some research, I elected to give Emby a try. Installation and setup went great. My Plex library has about 6000 movies. To test Emby, I only put 7 movies in my Emby Test Folder. Everything looked great, and was getting ready to add all my movies into Emby, but I noticed something a little off. With only 7 movies in the library, I can be in any screen, take your pick, and when I hit the Home Button, it takes about 30 seconds to load. Going to any other screen is instantaneous, but then going back home, I get the little swirling circle for about 30 seconds, every time, even though no new media has been placed in the library. All the YT video's that I watched doing my research, appeared to be instant with their install upon hitting Home. Age or power is not an issue with the dedicated Win 10 PC that I am running the Emby Media Server on. I am hoping that it is just a configuration issue. This is the only issue that I have found that is keeping me from dumping Plex and going full bore with Emby. For what it worth, I searched the Forum before posting, and could not find anything related. Please forgive me if I missed it or posted my problem in the wrong area. Thanks in advance for any suggestions.
Abobader 3485 Posted September 11, 2021 Posted September 11, 2021 Hello thurwill, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Happy2Play 9800 Posted September 11, 2021 Posted September 11, 2021 I would say there is definitely something wrong in that install taking 30 seconds to get back to Home Screen with a library of only 7 items. But what client/app? Wired or wireless? Local vs Remote? Hardware and harddrive type Emby is on? Overall Navigation back to Home should be instant as everything is known/cached already.
thurwill 1 Posted September 11, 2021 Author Posted September 11, 2021 Firefox Web App Wired Local External Raid Drives
Happy2Play 9800 Posted September 11, 2021 Posted September 11, 2021 Devs may need to see a server log showing this issue per the linked topic above.
Luke 42186 Posted September 12, 2021 Posted September 12, 2021 Hi there, can we please look at an example? Please attach the information requested in how to report a problem. thanks !
thurwill 1 Posted September 12, 2021 Author Posted September 12, 2021 Hopefully this is the right file. If not, please let me know. Thanks embyserver.txt
Luke 42186 Posted September 13, 2021 Posted September 13, 2021 55 minutes ago, thurwill said: Any idea's yet? Hi, the responses in this log file look fast to me. Are you sure this log file is from when the time the problem was experienced?
thurwill 1 Posted September 14, 2021 Author Posted September 14, 2021 Sorry for the delay. I had to wait to get back home from work to check something out. I wasn't aware that a new log was created for each day. After my post on Sunday, I started playing around with some of the configurations. After that, as of now, it goes to the Home screen instantly. Before the changes, it was taking an average of 20 to 25 seconds to go to the Home screen. I originally had it set to have a background image on the Home screen. Once I turned it off, everything worked great. I think it was taking that 20 to 25 seconds to compile the background images from my movies. I may be wrong, but I think that was the problem. Does that sound right to you?
ebr 16307 Posted September 14, 2021 Posted September 14, 2021 1 hour ago, thurwill said: Does that sound right to you? No, it doesn't. That should not have much of an impact. If you turn that option back on, do you see poor performance again?
thurwill 1 Posted September 14, 2021 Author Posted September 14, 2021 I'll give it a try when I get back home from work this afternoon. 1
thurwill 1 Posted September 14, 2021 Author Posted September 14, 2021 I turned that option back on, and I did not see a performance issue. I am at a lose. Everything seems to be working OK. If I start to encounter the issues again, I will update my post. Thanks for all the input and suggestions. As for now, everything seems to be working flawlessly.
Carlo 4561 Posted September 14, 2021 Posted September 14, 2021 1 hour ago, thurwill said: As for now, everything seems to be working flawlessly. Let's hope it stays that way. Thanks for the update.
Schakine 0 Posted March 2, 2023 Posted March 2, 2023 i had same issue when i fist installed Emby.. I came back to my sylomogy 418play, and closed emby server and then restarted it and ...magic the problem was solved..As simple as that....
visproduction 328 Posted March 2, 2023 Posted March 2, 2023 Remember to check for other apps running on your server at the same time you are opening Emby. Quite often an auto virus check can cause delay in other programs. Shortcut to task manager in Windows is [Ctrl] [Shift] [Esc].
