mark235 5 Posted September 10, 2021 Posted September 10, 2021 I have a GT710 in my HP microserver Gen8 which transcodes 1080p material just fine. But after upgrading to a 4K HDR tv, I noticed that this card cannot handle 4K source material. Thing is, my homeserver only allows for single slot low profile GPU's and has some PSU limitations. The GPU should not draw more than 75 watts, and that's already pushing things a bit. Upgrading to a Quicksync CPU isn't possible in this Microserver. The GT1030 appears to be out, according to this list: Video Encode and Decode GPU Support Matrix [NEW] | NVIDIA Developer. The GTX1050 would be nice but doesn't have single slot low profile editions. The Quadro P400 meets the requirements and supports up to 8k decoding. Plus it only draws 30 watts. It can only do 1 stream, but that's fine for now. Is this Quadro card supported in Emby?
Luke 42198 Posted September 10, 2021 Posted September 10, 2021 Hi, you may want to take a look at the hardware section where you can find opinions of different hardware options for use with Emby Server: https://emby.media/community/index.php?/forum/168-hardware/ 1
