Happy2Play 9811 Posted September 11, 2021 Posted September 11, 2021 8 hours ago, Joechung said: Yes, I have already referred to the EMBY external connection part. I can connect to the external network at present, but occasionally the connection crashes and I need to log in again, so I want to ask if I should fill in the IP through the EMBY network settings Can I connect more quickly in the public network? There are no additional setting if you can connect remotely. Emby will be dependent on the public connection and the public routes it takes to stream from your server.
Joechung 5 Posted September 12, 2021 Author Posted September 12, 2021 9 hours ago, Happy2Play said: There are no additional setting if you can connect remotely. Emby will be dependent on the public connection and the public routes it takes to stream from your server. 非常感谢!
