Joechung 5 Posted September 10, 2021 Posted September 10, 2021 Urgent help! ! ! Dear EMBY technical engineer, there are trailers in the movie files. How do you edit them to display the trailers in EMBY? Inside the red frame are the trailers. Now EMBY has become two independent movies.
GrimReaper 4896 Posted September 10, 2021 Posted September 10, 2021 You need to name it <moviefilename>-trailer.ext or put it in \trailers subfolder.
Joechung 5 Posted September 10, 2021 Author Posted September 10, 2021 2 minutes ago, GrimReaper said: You need to name it <moviefilename>-trailer.ext or put it in \trailers subfolder. Hello, can you have a specific screenshot for me? I don't quite understand how you do it. Thank you
GrimReaper 4896 Posted September 10, 2021 Posted September 10, 2021 Rename your trailer to: Life.2017.2160p.BluRay.x265.10bit.SDR.DTS-HD.MA.TrueHD.7.1.Atmos-SWTYBLZ-trailer.mkv or Create a subfolder named "trailers" and move trailer.mkv there.
Joechung 5 Posted September 10, 2021 Author Posted September 10, 2021 18 minutes ago, GrimReaper said: 将您的预告片重命名为: Life.2017.2160p.BluRay.x265.10bit.SDR.DTS-HD.MA.TrueHD.7.1.Atmos-SWTYBLZ-trailer.mkv 或者 创建一个名为“trailers”的子文件夹,然后将 Trailer.mkv 移动到那里。 I tried to change it, but there was no preview.
Joechung 5 Posted September 10, 2021 Author Posted September 10, 2021 2 minutes ago, GrimReaper said: 你后来扫描图书馆了吗? Yes, scan every time it is changed.
GrimReaper 4896 Posted September 10, 2021 Posted September 10, 2021 Well, make sure it is named EXACTLY as your movie file. Even single character difference will throw it off.
Joechung 5 Posted September 10, 2021 Author Posted September 10, 2021 1 minute ago, GrimReaper said: Well, make sure it is named EXACTLY as your movie file. Even single character difference will throw it off. I confirm that it is the same, I will take a screenshot for you to see.
Joechung 5 Posted September 10, 2021 Author Posted September 10, 2021 Hello, I used the mobile phone EMBY to test the trailer. It can be played normally, but the web version does not know if there is a delay, so it is not displayed. thanks
GrimReaper 4896 Posted September 10, 2021 Posted September 10, 2021 That seems correct. Do you still see double-entry in your library for that movie? Try creating a 'trailers' subfolder, move your trailer there and rescan.
rbjtech 5341 Posted September 10, 2021 Posted September 10, 2021 Clear the cache on the browser and try again.
Joechung 5 Posted September 11, 2021 Author Posted September 11, 2021 14 hours ago, GrimReaper said: 这似乎是正确的。您还在图书馆中看到那部电影的复式条目吗? 尝试创建一个“预告片”子文件夹,将预告片移到那里并重新扫描。 Why does another trailer appear when I play other movies? IMG_1835.MP4
Happy2Play 9811 Posted September 11, 2021 Posted September 11, 2021 3 hours ago, Joechung said: Why does another trailer appear when I play other movies? IMG_1835.MP4 No idea what you are pressing in that video, but if I had to guess you Cinema mode enabled so other media trailers play before your movie. 1
Joechung 5 Posted September 11, 2021 Author Posted September 11, 2021 8 minutes ago, Happy2Play said: No idea what you are pressing in that video, but if I had to guess you Cinema mode enabled so other media trailers play before your movie. Hello, let me re-upload it and play it on the computer for you to see. Action 2021-9-11 17-46-35.mp4
Happy2Play 9811 Posted September 11, 2021 Posted September 11, 2021 (edited) 8 minutes ago, Joechung said: Hello, let me re-upload it and play it on the computer for you to see. Action 2021-9-11 17-46-35.mp4 To me that looks like Cinema Mode but not seeing other local trailers. Pretty sure it is a device setting, User settings-Playback-enable Cinema Intros, along with the Cinema Intros plugin setting. Edited September 11, 2021 by Happy2Play
Joechung 5 Posted September 11, 2021 Author Posted September 11, 2021 9 minutes ago, Happy2Play said: To me that looks like Cinema Mode but not seeing other local trailers. Pretty sure it is a device setting, User settings-Playback-enable Cinema Intros, along with the Cinema Intros plugin setting. Hello, thank you very much, I unchecked and the problem was solved.
Joechung 5 Posted September 11, 2021 Author Posted September 11, 2021 Hello. In addition, I would like to ask, why some of my movies cannot be played? I am a lifetime EMBY secret key. I think all movies are output directly without transcoding. May I ask why some movies can be played directly but some are not? Action 2021-9-11 18-13-42.mp4
Happy2Play 9811 Posted September 11, 2021 Posted September 11, 2021 Just now, Joechung said: Hello. In addition, I would like to ask, why some of my movies cannot be played? I am a lifetime EMBY secret key. I think all movies are output directly without transcoding. May I ask why some movies can be played directly but some are not? Action 2021-9-11 18-13-42.mp4 That is a browser correct? Most browsers do not support HEVC so since you disable the options to convert the media, Emby can not play it per the note under those options. But if you feel something should Direct Play, please provide media info, the client version and server log.
Joechung 5 Posted September 11, 2021 Author Posted September 11, 2021 2 minutes ago, Happy2Play said: That is a browser correct? Most browsers do not support HEVC so since you disable the options to convert the media, Emby can not play it per the note under those options. But if you feel something should Direct Play, please provide media info, the client version and server log. Yes, you are very correct. I use Google Chrome to play it. There is no way to play it directly, right? Unless I choose to transcode, right?
Happy2Play 9811 Posted September 11, 2021 Posted September 11, 2021 (edited) 5 minutes ago, Joechung said: Yes, you are very correct. I use Google Chrome to play it. There is no way to play it directly, right? Unless I choose to transcode, right? Currently correct. Until browsers start supporting the codec there isn't anything anyone can do. But you could use the desktop version of Emby Theater. Emby Theater - Emby Edited September 11, 2021 by Happy2Play
Joechung 5 Posted September 11, 2021 Author Posted September 11, 2021 (edited) 14分钟前,Happy2Play 说: 目前正确。在浏览器开始支持编解码器之前,任何人都无能为力。 但是您可以使用 Emby Theater 的桌面版本。 恩比剧院 - 恩比 Thank you very much for your reply. I am very satisfied. In addition, I will simply continue to ask you about other problems I encountered. I am a public IP, and my broadband IP can be used directly in other places. I have mapped port 8096, but I don't know how to set it accurately in EMBY. 行动 2021-9-11 18-41-28.mp4 Edited September 11, 2021 by Joechung
Happy2Play 9811 Posted September 11, 2021 Posted September 11, 2021 3 minutes ago, Joechung said: Thank you very much for your reply. I am very satisfied. In addition, I will simply continue to ask you about other problems I encountered. I am a public IP, and my broadband IP can be used directly in other places. I have mapped port 8096, but I don't know how to set it accurately in EMBY. 行动 2021-9-11 18-41-28.mp4 Have you look at through the Knowledge Base? Emby Connectivity : Emby See External Connections section
Joechung 5 Posted September 11, 2021 Author Posted September 11, 2021 16 minutes ago, Happy2Play said: Have you look at through the Knowledge Base? Emby Connectivity : Emby See External Connections section Yes, I have already referred to the EMBY external connection part. I can connect to the external network at present, but occasionally the connection crashes and I need to log in again, so I want to ask if I should fill in the IP through the EMBY network settings Can I connect more quickly in the public network?
Luke 42240 Posted September 11, 2021 Posted September 11, 2021 8 hours ago, Joechung said: Hello, thank you very much, I unchecked and the problem was solved. Why did you enable Cinema Intros in the first place? What were you expecting it to do?
