robson alcantara 0 Posted September 10, 2021 Posted September 10, 2021 I would like to know at best what maximum number of devices I can connect
GrimReaper 4861 Posted September 10, 2021 Posted September 10, 2021 Standard Premiere subscription has 25 devices cap. You can opt for Extended Premiere options which would carry higher device limits. https://emby.media/premiere-ext.html 1
Happy2Play 9802 Posted September 10, 2021 Posted September 10, 2021 There is no true answer to this question as you can use as many clients that do not require premiere/unlock as your hardware can handle. So it really depends on the features you will be using and the client/apps used. Emby Premiere Feature Matrix : Emby 1
ebr 16309 Posted September 10, 2021 Posted September 10, 2021 11 hours ago, Happy2Play said: There is no true answer to this question as you can use as many clients that do not require premiere/unlock as your hardware can handle. So it really depends on the features you will be using and the client/apps used. Emby Premiere Feature Matrix : Emby Correct. There is no actual limit on devices in general. Only for Premiere features. 1
