Dave9999 4 Posted September 8, 2021 Posted September 8, 2021 Client - Nvidia Shield Pro 2019 Server - Synology DSM 7, Emby Server 4.6.4 Soundbar - Sonos Arc / HdFURY Arcana Nvidia Shield Audio advanced output set to Manual, all on except DTS which Sonos does not support. Sonos app shows PCM 2.0 on Emby. Plex outputs TrueHD from same setup. TrueHS passthrough enabled in Emby player. Is there a setting I'm missing?
Solution Dave9999 4 Posted September 8, 2021 Author Solution Posted September 8, 2021 I found that if I changed the Shield Advanced Audio from Manual to Auto-Detect and restarted the Shield, it plays properly. 1
ebr 16338 Posted September 8, 2021 Posted September 8, 2021 2 hours ago, Dave9999 said: I found that if I changed the Shield Advanced Audio from Manual to Auto-Detect and restarted the Shield, it plays properly. Bingo. Glad you figured it out.
