ryzilla 13 Posted September 3, 2014 Posted September 3, 2014 Hey All, Got a really annoying issue that i am having a hard time trying to fix. When i add a TV show in particular if the show has missing backdrops or artwork it get replaced by some dude and all these women (see screenshot below) And i cant get rid of him unless i go in manually and delete the pictures and browse for a relevant one? Anyone else have this issue? or know how to fix it? Cheers
iainsheppard 5 Posted September 3, 2014 Posted September 3, 2014 I also have this for my TV when I add a new show, I have been manually changing it. But when my son tells my wife I downloaded him a new show with girls and boobs it looks dodgy 1
Happy2Play 9798 Posted September 3, 2014 Posted September 3, 2014 I have had the same thing happen. Some how I get a series.xml in the season folder and then end up with those images.
iainsheppard 5 Posted September 3, 2014 Posted September 3, 2014 Yes I get a series.xml in the Season folder when it should just be the season.xml. I have metadata set to MB2 under basic.
ryzilla 13 Posted September 3, 2014 Author Posted September 3, 2014 this is the series.xml found under the following folder E:\Sleepy Hollow\Season 1 <?xml version="1.0" encoding="utf-8" standalone="yes"?> <Series> <id>85519</id> <Status>Ended</Status> <FirstAired>0001-01-01</FirstAired> <Added>27/08/2014 10:07:30 PM</Added> <LockData>false</LockData> <Overview><![CDATA[For the Love of Ray J is a dating show on VH1 featuring hip hop singer Ray J. The program has a format similar to Flavor of Love, I Love New York, and Rock of Love. One source notes that it "will be produced by the same geniuses" as those shows, 51 Minds. In reference to the series, Ray J said: The show, which premiered on February 2, 2009, follows Ray J and his entourage of female suitors to the hottest hangouts in Los Angeles, to Sin City where they’ll party with his famous friends, and to Ray’s childhood home where they’ll meet his family and older sister Brandy. Ray J will pour his heart out to these women in hopes that he can figure out who is really there for him. Each week the ladies will attempt to win over Ray J as he carries on with his life in the spotlight. In the end, the girls who can’t keep up with Ray J’s jet-setting ways will be sent packing. But the one who can impress his friends and family and make Ray J believe that love exists, will win the ultimate prize—the love of Ray J. According to one commentator, the concept of the show involves pampering the contestants with "upscale trips throughout the series" and "Ray J's so in love that he's already given participating girls names like Cashmere, Unique and Hot Cocoa."]]></Overview> <LocalTitle>For the Love of Ray J - Season 1</LocalTitle> <PremiereDate>0001-01-01</PremiereDate> <EndDate>0001-01-01</EndDate> <Rating>0</Rating> <VoteCount>0</VoteCount> <Website>http://www.vh1.com/shows/dyn/for_the_love_of_rayj/series.jhtml</Website> <RunningTime>0</RunningTime> <TMDbId>16268</TMDbId> </Series>
Luke 42184 Posted September 3, 2014 Posted September 3, 2014 can you post some screenshots of the contents of the series and season folder? thanks.
ryzilla 13 Posted September 3, 2014 Author Posted September 3, 2014 series.xml is listed in my above post
Luke 42184 Posted September 3, 2014 Posted September 3, 2014 was the series folder under season 1 recently created?
ryzilla 13 Posted September 3, 2014 Author Posted September 3, 2014 Yes, i added legends only 3 days ago and it auto appeared there. It has been happening for the last couple of months.
Luke 42184 Posted September 3, 2014 Posted September 3, 2014 can you post a log from starting up the server (with debug mode enabled) ? does the series appear as normal in the web client?
ryzilla 13 Posted September 3, 2014 Author Posted September 3, 2014 (edited) different TV show as i just fixed manually legends sorry same issue with sleepy hollow the same series.xml is under season 1 folder. Getting log file now. Edited September 3, 2014 by ryzilla
ryzilla 13 Posted September 3, 2014 Author Posted September 3, 2014 FYI now i deleted all data from Legends and it worked fine after rescan
Luke 42184 Posted September 3, 2014 Posted September 3, 2014 according to your log sleepy hollow looks normal. what is the problem with that? i would guess that Opposite Worlds or Gotham might not look right in the web client
ryzilla 13 Posted September 3, 2014 Author Posted September 3, 2014 The season images are all messed up has that dude and the chick in there
Luke 42184 Posted September 3, 2014 Posted September 3, 2014 ok, unfortunately because nothing obvious stands out i would need to see the log from when they were added to the library. so the next time the problem occurs, hold onto that. in the meantime just use the metadata manager to get the right images.
ryzilla 13 Posted September 3, 2014 Author Posted September 3, 2014 ok thanks i will keep a eye out and hope maybe someone else has these logs as well.
ebr 16306 Posted September 3, 2014 Posted September 3, 2014 I can tell you exactly what causes this. Adding a new TV series without a season folder in it. I now very quickly add a season 1 folder to all new TV series to keep this from happening but we really need a better way. 1
ryzilla 13 Posted September 4, 2014 Author Posted September 4, 2014 Thanks ebr i will give it a test and see what happens
Happy2Play 9798 Posted September 4, 2014 Posted September 4, 2014 (edited) The happened when I added Rosemary's Baby, I use MCM so I don't know if that has a factor in this but everything is just as ebr described. Look at line 5336-5354. http://paste2.org/PxGMzP3b Edited September 4, 2014 by Happy2Play
