horstepipe 423 Posted September 8, 2021 Posted September 8, 2021 Hello I setup hw transcoding successfully, now I wanted to enable transcoding for one user as he has a very limited bandwidth (16mbit/s). But it looks like there are no settings for this in the Apple TV app? I only see it for music, but not for video…?
Luke 42241 Posted September 8, 2021 Posted September 8, 2021 HI, you can set the app's playback quality setting in the Apple TV app.
ebr 16334 Posted September 8, 2021 Posted September 8, 2021 6 hours ago, horstepipe said: I wanted to enable transcoding for one user as he has a very limited bandwidth Transcoding permissions are done in the user setup panel on the server...
Happy2Play 9811 Posted September 9, 2021 Posted September 9, 2021 Little confused on exactly what you are asking but wouldn't you just set a stream limit on the User, so anything over 16Mbps will automatically transcode? But from a specific device perspective the user would have to set the playback quality on the device.
horstepipe 423 Posted September 10, 2021 Author Posted September 10, 2021 sorry guys, not sure whether there was some kind of ui glitch or whether I just was stupid. the settings are there now.
horstepipe 423 Posted September 11, 2021 Author Posted September 11, 2021 (edited) would it be possible adding a 10mbit/s transcoding selection? The user I want to set this up for has 12mbit/s Edited September 11, 2021 by horstepipe 1
Luke 42241 Posted September 11, 2021 Posted September 11, 2021 Yes we can look at expanding the options. Thanks.
