tdiguy 99 Posted September 6, 2021 Posted September 6, 2021 I have two channels in a m3u tuner setup that emby doesnt seem to like to seperate. USA Cartoon Network UHD and USA Cartoon Network East they are both tagged as: usacartoonnetwork which might be the underlying issue, but i suspect that changing that will cause issues with the epg. the 2 streams are different url's but emby doesnt seem to care. Is there a good way to force emby to recognize both of these as being the same but different, since their epg should be the same, its the resolution thats different. (720 vs 1080)
tdiguy 99 Posted September 7, 2021 Author Posted September 7, 2021 (edited) NM, did not work as i thought it did. Edited September 7, 2021 by tdiguy
Luke 42243 Posted September 7, 2021 Posted September 7, 2021 HI, if you give them unique tvg-id's in the m3u, that will separate them. Please let us know if this helps. Thanks. 1
