shdwkeeper 15 Posted September 2, 2021 Posted September 2, 2021 (edited) I'm on the latest beta 4.7.0.9 (Qnap) and my conversions are failing as well. Any update on the fix yet? Edited September 2, 2021 by shdwkeeper
Luke 42240 Posted September 2, 2021 Posted September 2, 2021 14 minutes ago, shdwkeeper said: I'm on the latest beta 4.7.0.9 (Qnap) and my conversions are failing as well. Any update on the fix yet? Hi there @shdwkeeper let's look at an example: Thanks.
shdwkeeper 15 Posted September 2, 2021 Author Posted September 2, 2021 7 minutes ago, Luke said: Hi there @shdwkeeper let's look at an example: Thanks. What do you want to see? Logs?
Luke 42240 Posted September 2, 2021 Posted September 2, 2021 16 minutes ago, shdwkeeper said: What do you want to see? Logs? Yes, and the information that is requested in my link above. Thanks.
shdwkeeper 15 Posted September 2, 2021 Author Posted September 2, 2021 46 minutes ago, Luke said: Yes, and the information that is requested in my link above. Thanks. Here are the logs from the server. All of these files play perfectly fine inside and outside of Emby. ffmpeg-transcode-15aaa5ec-7647-49b6-a131-c9380c4ecdb9_1.txt ffmpeg-transcode-b94f7baf-2862-4072-9090-0308ccc1e5f4_1.txt ffmpeg-transcode-1f99c1c1-2da4-4cd4-a060-10babcff0880_1.txt
shdwkeeper 15 Posted September 2, 2021 Author Posted September 2, 2021 Ok, it seems like the issue is with the Quicksync Encoder. I've attached some FAILED and SUCCESS files below. The conversions fail when I have the Quicksync encoder selected instead of VAAPI. The Quicksync decoder seems fine as long as the encoder is set to VAAPI. I'll try some more tests. ffmpeg-transcode-9a1e8e53-1898-409c-b5af-67c316d343c2_1-FAILED_h264.txt ffmpeg-transcode-7a6a5c40-15da-48fc-a524-6aece206f9c8_1-SUCCESS_h264.txt ffmpeg-transcode-1f99c1c1-2da4-4cd4-a060-10babcff0880_1-FAILED_h264.txt ffmpeg-transcode-3459dd81-a0a9-4cff-9b7f-beafb379d11f_1-SUCCESS.txt 1
Luke 42240 Posted September 2, 2021 Posted September 2, 2021 1 hour ago, shdwkeeper said: Ok, it seems like the issue is with the Quicksync Encoder. I've attached some FAILED and SUCCESS files below. The conversions fail when I have the Quicksync encoder selected instead of VAAPI. The Quicksync decoder seems fine as long as the encoder is set to VAAPI. I'll try some more tests. ffmpeg-transcode-9a1e8e53-1898-409c-b5af-67c316d343c2_1-FAILED_h264.txt 170.38 kB · 0 downloads ffmpeg-transcode-7a6a5c40-15da-48fc-a524-6aece206f9c8_1-SUCCESS_h264.txt 300.99 kB · 0 downloads ffmpeg-transcode-1f99c1c1-2da4-4cd4-a060-10babcff0880_1-FAILED_h264.txt 198.49 kB · 0 downloads ffmpeg-transcode-3459dd81-a0a9-4cff-9b7f-beafb379d11f_1-SUCCESS.txt 162.27 kB · 0 downloads This section of the community is about the android server. Is that what you're running?
shdwkeeper 15 Posted September 2, 2021 Author Posted September 2, 2021 (edited) 4 minutes ago, Luke said: This section of the community is about the android server. Is that what you're running? QNAP server - SHOOT sorry about that. Well, its good info anyway Edited September 2, 2021 by shdwkeeper
shdwkeeper 15 Posted September 3, 2021 Author Posted September 3, 2021 @LukeMaybe change this topic to QNAP Server and just put my posts about my error in this NEW topic. Than move the rest of the topic back to Android Server since that is what most of this topic was about? @Happy2Play can you split this topic starting with shdwkeeper's first posting above and move his part of the conversation into a new topic in the QNAP section? Thanks.
shdwkeeper 15 Posted September 5, 2021 Author Posted September 5, 2021 (edited) Any ideas on the Quicksync Failed error? Edited September 5, 2021 by shdwkeeper
softworkz 5133 Posted October 4, 2021 Posted October 4, 2021 (edited) @shdwkeeper - Please excuse the late reply and thanks for posting the log files. TBH, I've never seen an error like this. Let's look at the facts first: QuickSync is working basically Transcoding videos runs fine until the end Only at the end, when a qsv codec is about to be deallocated there's a crash occurring There haven't been any similar reports from other users, not on Qnap nor on regular Linux systems It's not easy to identify the cause of this as there are no "usual suspects" for this kind of error. This could be caused by any of these: Intel Media Driver (VAAPI) libva Intel Media SDK Runtime (libmfx) gmmlib (Intel Memory Mgmt) Kernel driver for Intel Graphics System libs System confguration Hardware/Bios What's unlikely though, is a problem in "Emby Server" and "Emby-ffmpeg" Edited October 4, 2021 by softworkz
softworkz 5133 Posted October 4, 2021 Posted October 4, 2021 Now we have the following options: Disable the QSV encoders use the VAAPI encoders instead and wait for future updates that will probably (hopefully) fix this Try to pinpoint the problem I can guide you through it but it could be a long way at the end, we might know the cause, but might still need to wait until it's fixed by Intel
