Paul898 0 Posted September 5, 2021 Posted September 5, 2021 Hey, I am NEW to Emby. Is there a way to to have the server install on a specific drive? I have a small C drive where windows is located and would like to have Emby and all the data and logs for it located on my D drive that is a lot larger. How can i set it up on a drive Different drive? From what i see most logs and files can be moved but not the program. please help
Abobader 3485 Posted September 5, 2021 Posted September 5, 2021 Hello Paul898, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Happy2Play 9802 Posted September 5, 2021 Posted September 5, 2021 On Windows you can move the install from its current location as the installer will not allow path change or you can get the portable from the download page and put it where you like.
Luke 42200 Posted September 5, 2021 Posted September 5, 2021 You can also start fresh with the portable install if you want.
