Carlo 4561 Posted September 6, 2021 Posted September 6, 2021 Yes that seems like a good idea. Test again tomorrow to see if you get another new batch of subs downloaded.
iJoMun 11 Posted September 10, 2021 Author Posted September 10, 2021 (edited) 31 minutes ago, Luke said: @iJoMun has this helped? Hi Luke. No it has not. I still have many movies and shows missing subs (srt). Running Scheduled tasks manually does not seem to fill in the gaps. I've been manually downloading the srt files for movies and shows as I play them. Edited September 10, 2021 by iJoMun
Solution Luke 42198 Posted September 10, 2021 Solution Posted September 10, 2021 Then it sounds like your download options are too restrictive and that's why you're not getting automated downloads. Either that or it's just going to take a while due to the daily limit.
iJoMun 11 Posted September 10, 2021 Author Posted September 10, 2021 1 minute ago, Luke said: Then it sounds like your download options are too restrictive and that's why you're not getting automated downloads. Either that or it's just going to take a while due to the daily limit. My download options (as you can see on the first page) don't seem restrictive at all, unless I'm missing something. You may be right however, it might just take some time for the library to catch up. Thank you for your help. I'm ready to chose this thread.
