pir8radio 1313 Posted September 20, 2021 Posted September 20, 2021 another thing to check with caching back on standard.. is make sure you DO NOT have any kind of rule that says CACHE EVERYTHING. your video files (.ts) should be showing up as dynamic. meaning not cached. if you enable cache everything anywhere but for the images, this is your problem.
vaise 340 Posted September 20, 2021 Posted September 20, 2021 Hi @pir8radio Can you post your page rules to compare to mine. Thanks.
pir8radio 1313 Posted September 20, 2021 Posted September 20, 2021 14 minutes ago, vaise said: Hi @pir8radio Can you post your page rules to compare to mine. Thanks. The #1 not shown is just a redirect i use for uptime robot to route directly to their status page, not needed here.. but #2 and #3 shown here are what i use.. #2 caches images.. it must be cache everything (but only that pattern emby/items/*/Images/*) the reason for cache everything that matches that pattern is that emby image files do not have an extension... for example here is a link to an emby image: /emby/Items/13486951/Images/Primary?maxHeight=300&maxWidth=200&tag=15faecxxxxxxxxxx1208029ef21855&quality=90 notice primary has no extension? so cloudflare doesn't know primary is an image... so you have to tell it to cache everything. my #3 rule is optional, usually cloudflare will wipe its edge server cache after like 30 mins... but i want all of my images cached on those servers when a user comes back the next day or a month later. If you guys continue to have issues, we can look into a rule that does cache level: bypass and have the rule match any /*.ts* file, meaning do not cache video files, or even M3U files, but cloudflare should be identifying these as DYNAMIC files unless you have "CACHE EVERYTHING" enabled somewhere.
vaise 340 Posted September 20, 2021 Posted September 20, 2021 1 minute ago, pir8radio said: The #1 not shown is just a redirect i use for uptime robot to route directly to their status page, not needed here.. but #2 and #3 shown here are what i use.. #2 caches images.. it must be cache everything (but only that pattern emby/items/*/Images/*) the reason for cache everything that matches that pattern is that emby image files do not have an extension... for example here is a link to an emby image: /emby/Items/13486951/Images/Primary?maxHeight=300&maxWidth=200&tag=15faecxxxxxxxxxx1208029ef21855&quality=90 notice primary has no extension? so cloudflare doesn't know primary is an image... so you have to tell it to cache everything. my #3 rule is optional, usually cloudflare will wipe its edge server cache after like 30 mins... but i want all of my images cached on those servers when a user comes back the next day or a month later. If you guys continue to have issues, we can look into a rule that does cache level: bypass and have the rule match any /*.ts* file, meaning do not cache video files, or even M3U files, but cloudflare should be identifying these as DYNAMIC files unless you have "CACHE EVERYTHING" enabled somewhere. That is EXACTLY what I have (diff domain names of course)........ so we are no closer to the cause.......
vaise 340 Posted September 20, 2021 Posted September 20, 2021 I just tested again - flipped to standard on the caching, get the media slow start. flipped off again and cleared cache - all fast again.
pir8radio 1313 Posted September 20, 2021 Posted September 20, 2021 21 minutes ago, vaise said: I just tested again - flipped to standard on the caching, get the media slow start. flipped off again and cleared cache - all fast again. in developer mode on the browser what do you see for your video files and stuff? you add the cf-cache-status column so you can see whats going on.. or if you want to enable it then pm me your server info i can try from here see if i get a different response?
pir8radio 1313 Posted September 20, 2021 Posted September 20, 2021 1 hour ago, tomnjerry74 said: Thanks for the info. For now I don't really see much of a choice unless we sacrifice the main functions of the server. Loading speed is moot when you can't even play content . i have not been able to reproduce.. if anyone wants to create a temporary account for me i would like to login and see if i can spot anything.. possibly modify Cloudflare and/or nginx settings if i find anything.
vaise 340 Posted September 21, 2021 Posted September 21, 2021 (edited) Maybe should continue this on the other thread as that is specific to my direct play issue (and @seanbuff), but these other peeps on this thread only talk about FF/skip type issues - even though they both started at the same tie and have the seem fix it seems (so may be linked to a cache issue). I also had sme users say some medai was going back to the beggining so i may have had the same as them. Edited September 21, 2021 by vaise
Luke 42198 Posted September 21, 2021 Posted September 21, 2021 1 hour ago, pir8radio said: another thing to check with caching back on standard.. is make sure you DO NOT have any kind of rule that says CACHE EVERYTHING. your video files (.ts) should be showing up as dynamic. meaning not cached. if you enable cache everything anywhere but for the images, this is your problem. Try something that direct plays. I think that's when this issue is most experienced. 1
pir8radio 1313 Posted September 21, 2021 Posted September 21, 2021 (edited) SEE THIS POST FOR CURRENT FIX: Edited September 21, 2021 by pir8radio
