damichab 2 Posted September 14, 2021 Author Posted September 14, 2021 14 hours ago, Luke said: You can get the apk for that here: https://emby.media/emby-for-android.html Thanks. I have had no experience with apk files... what am I supposed to do with it?
damichab 2 Posted September 14, 2021 Author Posted September 14, 2021 16 hours ago, ebr said: It doesn't like something in that file. 09-13 10:50:49.171 7391 7391 I System.out: ***** Got error from Exo player: Unexpected decode error Can you please side load the mobile app onto that same device and play the exact same thing and then, if it works okay, please attach the log from the mobile app? Thanks. I have played a variety of music (flac) files and they all do the same thing. The same files play ok from emby on the phone, if that helps. I will need step by step instructions on how to side load to the tv.
ebr 16337 Posted September 14, 2021 Posted September 14, 2021 https://www.howtogeek.com/336602/how-to-sideload-apps-on-the-fire-tv-and-fire-tv-stick/ This should apply to any Android TV device (not just a Fire).
damichab 2 Posted April 16, 2022 Author Posted April 16, 2022 I had stopped using Emby for playing music due to the frustrations this was causing me, but due to boredom (and isolation) gave it another try and hey, the problem appears to be fixed. Well done and thankyou!
