damichab 2 Posted September 5, 2021 Posted September 5, 2021 Setting up a Sony X1 TV with the Emby Android TV app... I have an emby server on a server computer. This Emby server has a Music library (called "Music") reading FLAC files from an artist/album/track configuration. Playing these FLAC files though Emby-Theatre on my normal computer I have no problems. But, however, playing the same files on the Android TV app, I can play all but the last two/threee seconds where I then see momentarily the message "Error playing audio". This is repeatable and happens for each and every file played. If I go into the playlist, I can forward to the next song which also plays up until the last couple of seconds and repeats with the error message. I am currently rebuilding the Music library, but this has not had any effect. Any ideas what is going wrong? -Thanks in advance, David.
Luke 42245 Posted September 5, 2021 Posted September 5, 2021 Hi there @damichab can we please look at an example? Please attach the information requested in how to report a media playback issue. thanks !
damichab 2 Posted September 6, 2021 Author Posted September 6, 2021 Hi Luke, The files I am testing are at: F:\Media\CD\Albums\David\Air Supply\The Essential Once the scans have all finished, I will run the tests again so that you get a 'clean' log with only the problem contained within. In the meantime, here is the current Activity and log file. Each song stopped 2 seconds shy of finishing. "Play all" was selected for the album. I had to forward each song to play the next. - David. embyserver.txt
Luke 42245 Posted September 6, 2021 Posted September 6, 2021 You said you're rebuilding the library. Has the initial library scan completed? It looks like there's still a lot of library scanning activity occuring.
damichab 2 Posted September 6, 2021 Author Posted September 6, 2021 Scan is still running - it seems to be taking a while. Mind you, yesterday I did delete and re-create most of the Libraries to change the content type which were mostly "Mixed type" (I thought it might have fixed the problem). Reading through the log file, is of course, all over the place. There are multiple System.ArgumentOutOfRangeException errors in the log that might be of interest to you as well. These seem to be more about image extraction. It would appear that the error message I get on the screen is not reported as an error in the log file - but that might just be me not knowing what the log file is reporting of course. I will re-run the tests when scanning has stopped. Music is on 99%, up from 92% yesterday.
damichab 2 Posted September 7, 2021 Author Posted September 7, 2021 Well ok.. finally got access to the TV... I stopped Emby service. I put the logging into debug mode. Started Emby. Went to the tv and selected the test album. Played Air Supply\Greatest Hits\01 Love and Other Bruises (FLAC) Song stopped 2 seconds before end of song. Used remote to forward to next song: 02 Bring Out the Magic (FLAC) Song stopped 2 seconds before end of song. Saved log file. If you need anything else, let me know. embyserver.txt
damichab 2 Posted September 7, 2021 Author Posted September 7, 2021 I just realised, not in debugging mode... doing it again.
damichab 2 Posted September 7, 2021 Author Posted September 7, 2021 Take two (with debugging mode really on)! embyserver.txt
ebr 16337 Posted September 7, 2021 Posted September 7, 2021 Hi. Can you please do this one more time and send a log from the app right after?
damichab 2 Posted September 7, 2021 Author Posted September 7, 2021 Hi ebr, I found the debugging option on the app on the TV, but cannot see how to send a log from the TV. Here are the log files from the server running the test again with TV android app debugging option enabled.embyserver.txthardware_detection-63766683342.txt
Luke 42245 Posted September 8, 2021 Posted September 8, 2021 Hi, can you try side loading our standard Android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
damichab 2 Posted September 8, 2021 Author Posted September 8, 2021 3 hours ago, Luke said: Hi, can you try side loading our standard Android app on the same device and see how that compares? The option to send it to the TV is greyed out. Apparently it is not compatible ("This item is not compatible with your device").
damichab 2 Posted September 8, 2021 Author Posted September 8, 2021 Just tested on a second TV. Same brand/series, slightly smaller model - does exactly the same thing.
damichab 2 Posted September 8, 2021 Author Posted September 8, 2021 Is working ok from my android phone!
ebr 16337 Posted September 8, 2021 Posted September 8, 2021 12 hours ago, damichab said: but cannot see how to send a log from the TV. Hi. The instructions for sending the log from the app are in the article I linked. There is an option under your user menu at the top of the home page.
Luke 42245 Posted September 8, 2021 Posted September 8, 2021 9 hours ago, damichab said: The option to send it to the TV is greyed out. Apparently it is not compatible ("This item is not compatible with your device"). You can sideload the apk from our website.
damichab 2 Posted September 10, 2021 Author Posted September 10, 2021 2 hours ago, Luke said: @damichab are you able to try this? I'll try this when I get a few spare minutes, give me a few days.
Luke 42245 Posted September 12, 2021 Posted September 12, 2021 On 9/10/2021 at 1:12 AM, damichab said: I'll try this when I get a few spare minutes, give me a few days. That would be very helpful. Thanks.
damichab 2 Posted September 13, 2021 Author Posted September 13, 2021 Hi Luke/ebr, I cannot find where in the link it explains how to sideload the app to the TV. No link attached explains how to do this. I can only get to the Google Play Store and the option for the TV is greyed out. Also, I cannot see the option to send the log file from the TV. I have the emby server's "Enable debug logging" enabled, but that does not create any other option under my name in the TV emby app. - David.
damichab 2 Posted September 13, 2021 Author Posted September 13, 2021 I have just found how to send log file from tv.
ebr 16337 Posted September 13, 2021 Posted September 13, 2021 It doesn't like something in that file. 09-13 10:50:49.171 7391 7391 I System.out: ***** Got error from Exo player: Unexpected decode error Can you please side load the mobile app onto that same device and play the exact same thing and then, if it works okay, please attach the log from the mobile app? Thanks.
Luke 42245 Posted September 13, 2021 Posted September 13, 2021 1 hour ago, ebr said: It doesn't like something in that file. 09-13 10:50:49.171 7391 7391 I System.out: ***** Got error from Exo player: Unexpected decode error Can you please side load the mobile app onto that same device and play the exact same thing and then, if it works okay, please attach the log from the mobile app? Thanks. You can get the apk for that here: https://emby.media/emby-for-android.html Thanks.
