Skyhigh69 7 Posted September 4, 2021 Posted September 4, 2021 any idea why collections are being doubled up? thanks. Windows, v4.6.4.0
Carlo 4561 Posted September 4, 2021 Posted September 4, 2021 Hi, if you look at your Collections ID from the library setup menu on Emby server what library type is shown under "Collections"?
Skyhigh69 7 Posted September 4, 2021 Author Posted September 4, 2021 sorry I have no idea what your asking for.
Carlo 4561 Posted September 4, 2021 Posted September 4, 2021 What does it show on your system in the red circle?
koopa8840 24 Posted September 4, 2021 Posted September 4, 2021 You're looking in the Metadata Manger. You need to go to the Server's config page, and look at the Library tab as @cayars shows.
Skyhigh69 7 Posted September 4, 2021 Author Posted September 4, 2021 1 minute ago, koopa8840 said: You're looking in the Metadata Manger. You need to go to the Server's config page, and look at the Library tab as @cayars shows. i did?
koopa8840 24 Posted September 4, 2021 Posted September 4, 2021 I still can't edit my posts. Anyways, my last post was posted as you posted your's, so please disregard since you posted a correct screenshot.
Skyhigh69 7 Posted September 4, 2021 Author Posted September 4, 2021 Yeah I cant edit either, I deleted the auto box sets
Carlo 4561 Posted September 4, 2021 Posted September 4, 2021 15 minutes ago, koopa8840 said: I still can't edit my posts. Anyways, my last post was posted as you posted your's, so please disregard since you posted a correct screenshot. You don't have "edit" from the 3 dot menu to the right?
Carlo 4561 Posted September 4, 2021 Posted September 4, 2021 OK that is showing as "Collections" type which is correct but your Music library is using "Mixed Content" vs Music type which likely isn't going to be ideal. Could you run a full library scan from the library menu and see if this removes the duplicates? If not we will need to manually make a couple of changes, delete the collection library and then rescan to fix it.
Skyhigh69 7 Posted September 4, 2021 Author Posted September 4, 2021 i did re run, no change, and music displays perfect so no sense messing with it.
Skyhigh69 7 Posted September 4, 2021 Author Posted September 4, 2021 collections does not have a remove feature like the others?
Skyhigh69 7 Posted September 4, 2021 Author Posted September 4, 2021 be nice to have an edit button so I dont have to make 1000 posts lol
Skyhigh69 7 Posted September 4, 2021 Author Posted September 4, 2021 collection has a edit only button
Happy2Play 9802 Posted September 4, 2021 Posted September 4, 2021 (edited) 10 minutes ago, Skyhigh69 said: music displays perfect so no sense messing with it. OT: But mixed content should not be showing media as it does not support audio files. You can try this Collections library?! But suspect a database issue. 5 minutes ago, Skyhigh69 said: be nice to have an edit button so I dont have to make 1000 posts lol @Abobaderis edit disabled for users now? Edited September 4, 2021 by Happy2Play 1
Skyhigh69 7 Posted September 4, 2021 Author Posted September 4, 2021 dosent help me happy, I dont have that directory, what else can I do
Carlo 4561 Posted September 4, 2021 Posted September 4, 2021 3 minutes ago, Skyhigh69 said: dosent help me happy, I dont have that directory, what else can I do What OS are you running Emby on?
Skyhigh69 7 Posted September 4, 2021 Author Posted September 4, 2021 (edited) windows 10, oh cool, edit button back, thanks, how bout a delete button for collections hahah. Edited September 4, 2021 by Skyhigh69
Abobader 3485 Posted September 4, 2021 Posted September 4, 2021 19 minutes ago, Skyhigh69 said: be nice to have an edit button so I dont have to make 1000 posts lol That will end you as a spammer, and sure you do not want that, please try to post complete post, not a post every minute or so. You can now edit your post with time as 10 mins, then you can not. 17 minutes ago, Happy2Play said: @Abobaderis edit disabled for users now? I was testing something, now "Member" group can edit their post within 10 mins timing from the original post time. 2
koopa8840 24 Posted September 4, 2021 Posted September 4, 2021 Try this path: Emby\programdata\root\default\Collections and follow Happy's suggestion.
Skyhigh69 7 Posted September 4, 2021 Author Posted September 4, 2021 (edited) Ok well I found my directory and I just deleted the collections folder, Let you no how I make out after a rescan. My directory is in AppData\Roaming\Emby-Server\programdata\root\default. Edited September 4, 2021 by Skyhigh69 1
Carlo 4561 Posted September 4, 2021 Posted September 4, 2021 11 minutes ago, Skyhigh69 said: dosent help me happy, I dont have that directory, what else can I do On Windows that path would be similar to this: C:\Users\carlo\AppData\Roaming\Emby-Server\programdata\root\default Change carlo above to your username used for Emby. Delete the Collections folder from that location.
