Truenas scale docker emby fails.
hoffmannlin
hello @Luke
i follow this post did.
but my system is debian11
root@truenas[~]# uname -a
Linux truenas.local 5.10.81+truenas #1 SMP Mon Dec 20 21:03:38 UTC 2021 x86_64 GNU/Linux
root@truenas[~]# echo  $(. /etc/os-release;echo $ID$VERSION_ID)
debian11
nvidia-docker only support debian9 and 10
https://nvidia.github.io/nvidia-docker/
but my docker version is 22.10.11
# docker info
Client:
 Context:    default
 Debug Mode: false
 Plugins:
  app: Docker App (Docker Inc., v0.9.1-beta3)
  buildx: Build with BuildKit (Docker Inc., v0.6.3-docker)
  scan: Docker Scan (Docker Inc., v0.9.0)
Server:
 Containers: 24
  Running: 11
  Paused: 0
  Stopped: 13
 Images: 16
 Server Version: 20.10.11
so i use
 --gpus all
to create docker
  • 1 year later...
On 9/13/2021 at 1:45 PM, KTBBQQ said:
@Luke
Successful!!!congratulations for me.
Thank you so much!
Hi KTBBQQ,
Glad you were able to get you acceleration!. I'm trying the exact same thing than you but with a 1080ti. Did you do a special step after those abose to make it run? I'm stuck. I don't see my gpu listing in EMBY app and I get the same :
  "Message": "Failed to initialize VA /dev/dri/renderD128. Error -1"
when I run the ffmpeg command.
If you could help me figure out what happen, I would appreciate!
Thanks
@Luke
Thank you so much!
Hi KTBBQQ,
Thanks
@Luke
Thank you so much!
Hi KTBBQQ,
Thanks
On 1/16/2022 at 8:55 AM, hoffmannlin said:
hello @Luke
debian11
# docker info
Client:
 Context:    default
 Debug Mode: false
 Plugins:
Server:
 Containers: 24
  Running: 11
  Paused: 0
  Stopped: 13
 Images: 16
so i use
 --gpus all
to create docker
Hello Hoffmanlinn,
Did you finally manage how to make it work?
Thanks
Edited by eraser8
typo
