GrimReaper 4899 Posted September 2, 2021 Posted September 2, 2021 Could you be a little more specific? Where?
mike3821 67 Posted September 2, 2021 Author Posted September 2, 2021 Just now, GrimReaper said: Could you be a little more specific? Where? Remotes with a guide button, do those physical buttons work with Emby?
GrimReaper 4899 Posted September 2, 2021 Posted September 2, 2021 Ah, remote. Not sure, tbh, likely no, but someone with actual EPG button would need to confirm that, mine doesn't have it. @cayars
Carlo 4561 Posted September 2, 2021 Posted September 2, 2021 I don't think so. I know on my Samsung remote if I hit the guide button the TV intercepts/processes it.
ebr 16338 Posted September 3, 2021 Posted September 3, 2021 Hi. The app supports it (will show the guide during playback) but I haven't found a TV yet that will pass it through to the app.
mike3821 67 Posted September 3, 2021 Author Posted September 3, 2021 2 minutes ago, ebr said: Hi. The app supports it (will show the guide during playback) but I haven't found a TV yet that will pass it through to the app. I am using the tivo stream 4K remote and the guide button during play of live tv doesn’t do anything. The guide button is a recognized butting under button mapper so android sees it… I could map this button to a keycode if one is available that would bring up the guide?
ebr 16338 Posted September 3, 2021 Posted September 3, 2021 1 minute ago, mike3821 said: I could map this button to a keycode if one is available that would bring up the guide? Try "menu".
mike3821 67 Posted September 3, 2021 Author Posted September 3, 2021 7 hours ago, ebr said: Try "menu". It already registers as menu.
mike3821 67 Posted September 4, 2021 Author Posted September 4, 2021 I managed to get this to work. Sorry it was registering as a guide button so I remapped to a custom keycode. It is now working. 1
