mediacowboy 438 Posted September 2, 2014 Posted September 2, 2014 (edited) So I can install media browser theater and even play a movie and browse like normal. Then I exit it and relaunch and I get a "Unhandled Expectation: An invalid physical address was specified." Attached are all logs since I re-installed my OS. I have installed the latest version of .NET 4.5, Lav filters, and updates.I would appreciate any help in this. Edit: MBT Version - 3.0.5355.20270 Error.zip Edited September 2, 2014 by mediacowboy
mediacowboy 438 Posted September 3, 2014 Author Posted September 3, 2014 So no one can help me figure out this error. I would love getting this to work as I will be carrying my laptop more and more.
mediacowboy 438 Posted September 4, 2014 Author Posted September 4, 2014 Ok, my apologies I just noticed that I shouldn't have zipped the log files. Here are new logs from today unzipped. Please someone help me with this as I plan to start carrying my laptop more and would love it use mbt. theater-63545446818.txt crash_c6bdfd53-47a9-4686-a9ba-31527e2c78b8.txt
Ghostm 75 Posted September 4, 2014 Posted September 4, 2014 Are you using mbt on your network or away from home?
mediacowboy 438 Posted September 5, 2014 Author Posted September 5, 2014 I have tried both ways. Both resulting in the error show in the first post.
Ghostm 75 Posted September 5, 2014 Posted September 5, 2014 (edited) I cant really help away from home I only use it on my network, whats your OS? Cant find anything that helps, only one other thread/case with this problem. http://mediabrowser.tv/community/index.php?/topic/7702-unhandled-exception-invalid-physical-address-was-specified/ Edited September 5, 2014 by Ghostm
mediacowboy 438 Posted September 5, 2014 Author Posted September 5, 2014 (edited) Windows 7 x64 Thanks, I found that thread to but it doesn't seem to help. I do appreciate the help maybe a dev will pop in and help. Edited September 5, 2014 by mediacowboy
ebr 16332 Posted September 5, 2014 Posted September 5, 2014 Looks like it is failing attempting to wake your server due to a bad mac address. But I can't find anywhere in the config where this address is stored. Probably if we can find it and clear it, MBT will start back up. @@Aphid
mediacowboy 438 Posted September 5, 2014 Author Posted September 5, 2014 Thank you @@ebr, I am currently at work away from that system but will look tonight
Solution Aphid 212 Posted September 5, 2014 Solution Posted September 5, 2014 Find system.xml in AppData/Roaming/MediaBrowser-Theater/config. Backup the file somewhere, then edit it and delete the entire <WakeOnLanConfiguration> section, including its enclosing tags. This should reset its settings, and MBT should re-configure itself when you next launch. 1
mediacowboy 438 Posted September 5, 2014 Author Posted September 5, 2014 Ok, I will try this when I get home and report back. Is there a way to disable the wake on LAN feature as my server is on 24/7?
Aphid 212 Posted September 5, 2014 Posted September 5, 2014 Not at the moment, no. We have made this code a little more robust, so it should not be causing crashes in future releases.
ebr 16332 Posted September 5, 2014 Posted September 5, 2014 Thanks Tom. My config file didn't have that section. I must not be on the latest MBT on this box.
mediacowboy 438 Posted September 6, 2014 Author Posted September 6, 2014 Thank you guys so much. That did it and then it updated and I can now close and open Media Browser Theater.
mediacowboy 438 Posted September 8, 2014 Author Posted September 8, 2014 This can be marked as resolved.
ebr 16332 Posted September 8, 2014 Posted September 8, 2014 This can be marked as resolved. And you can do it. Just hit the "Best Answer" button on the entry that solved your problem.
mediacowboy 438 Posted September 8, 2014 Author Posted September 8, 2014 Thank you, Didn't know I could do that.
