Djglaucio 4 Posted September 1, 2021 Posted September 1, 2021 Bom dia! Topico refente a todos membros que tem problemas com o guia de tv do emby server. Dicas,Sugestoes,Ajuda. Qual o "cep" do Brasil a ser colocado no login do schedules direct? tentei um monte de "ceps" inclusive o meu nenhum funcionou... o formato xmltv ja tentei de todo jeito nao da certo...se tivesse como tranformar a lista m3u em xmltv url...o problema seria resolvido aqui no Brasil.
Carlo 4561 Posted September 1, 2021 Posted September 1, 2021 Hi, we've traded a few PM on this topic but let me try to clear this up for you. The M3U file contains the channel into and stream information. The m3U does not contain any guide data. The m3u files is equivalent to having a hardware tuner. The XML file contains the guide data for channels but no stream information. The two files together give you the station/Channel, the stream for that channel and the ongoing guide data to list different shows/movies and the time they are being broadcast.. The m3u file can't be converted to an xml file as they contain very different information. These two files work together as a "package". That means the XML file is designed to work with the channels in a specific m3u file. Typically a provider will supply both the proper m3u file and xml file. If however you search the internet for "free" lists of channels you will likely only get the m3u file and not a guide so besides being highly unreliable lists they are not a complete solution since you need the guide data.
