MrVoid21 1 Posted August 31, 2021 Posted August 31, 2021 Hello.I am new to emby and i think it is a very good app.But I've had a problem.I have a lot of videos which have different audio codecs.For example the one in the photo.My tv supports eac3 but it still transcodes to aac.When the audio transcodes and i use the skip 10 seconds button the subtitles get delayed.Or when i use the resume where i left off button the subtitles get delayed too.I am using the emby app on my Lg Un 7100.
Luke 42237 Posted August 31, 2021 Posted August 31, 2021 Hi there, please attach the ffmpeg transcoding log from the server: Thanks.
MrVoid21 1 Posted August 31, 2021 Author Posted August 31, 2021 (edited) hereffmpeg-remux-5cbfc5dc-8f37-4738-b8d5-2131717bbe2c_1.txt Edited August 31, 2021 by MrVoid21
Luke 42237 Posted August 31, 2021 Posted August 31, 2021 OK the app tried to direct play the file, the LG video player raised an error when trying to play it, and then the app automatically switched to transcoding to make the file playable. The next update to the app will show this as the transcoding reason in the stats for nerds feature. Please let us know if this helps. Thanks.
MrVoid21 1 Posted August 31, 2021 Author Posted August 31, 2021 Well yeah sure but why can't it direct play?If my tv supports the audio codec?
Luke 42237 Posted August 31, 2021 Posted August 31, 2021 22 minutes ago, MrVoid21 said: Well yeah sure but why can't it direct play?If my tv supports the audio codec? There is probably an issue with the container file and not with the actual codecs within. It's hard to say and currently the app does not send the error information to the server for display, although even if we did, the LG video player only gives us a couple vague high level error codes like network error or media format error. But this should not be widespread with all files.
Luke 42237 Posted December 16, 2021 Posted December 16, 2021 Emby for LG TV's 1.0.31 has been released. Stay tuned to the blog for the release announcement.
