MBSki 1115 Posted September 20, 2021 Author Posted September 20, 2021 @Luke Following up. Can you please fix this issue?
MBSki 1115 Posted September 30, 2021 Author Posted September 30, 2021 @Luke Can you please provide a status on a fix?
Luke 42243 Posted September 30, 2021 Posted September 30, 2021 On 9/16/2021 at 11:24 AM, mbarylski said: Luke, it's in this thread. @cayars tested and provided the example. have you provided the log file from a recording?
MBSki 1115 Posted September 30, 2021 Author Posted September 30, 2021 It's not about recording, it's about what shows in the guide. Do a search for The Goldbergs and you'll see what we're talking about.
Luke 42243 Posted September 30, 2021 Posted September 30, 2021 17 minutes ago, mbarylski said: It's not about recording, it's about what shows in the guide. Do a search for The Goldbergs and you'll see what we're talking about. The whole first post of this thread is about recording. When I search I only have one Goldbergs.
MBSki 1115 Posted September 30, 2021 Author Posted September 30, 2021 4 minutes ago, Luke said: The whole first post of this thread is about recording. When I search I only have one Goldbergs. Both @cayars and I have 2. How could you only have 1?
Carlo 4561 Posted October 2, 2021 Posted October 2, 2021 I don't think there is anything Emby should do about this as it's a guide issue. When you have the same series listed with 2 different dates Emby has to assume these are different shows.
MBSki 1115 Posted October 2, 2021 Author Posted October 2, 2021 19 minutes ago, cayars said: I don't think there is anything Emby should do about this as it's a guide issue. When you have the same series listed with 2 different dates Emby has to assume these are different shows. It can't be a guide issue. Plex is using the same guide data and it's only picking up 1 show. I have Plex and Emby connected to the same Cable tuner on Verizon Fios.
Carlo 4561 Posted October 2, 2021 Posted October 2, 2021 Comparing to Plex doesn't mean anything as they both handle things differently. I was not saying that was the issue but we found out . If I look at this show from the guide I get this: But this show really is this: So it's quite possible in your area different channels are listing it both as 2013 and 2016 and Emby will treat this as two different shows. So try taking a look at the year on both of them.
MBSki 1115 Posted October 2, 2021 Author Posted October 2, 2021 I'm not sure what you mean. Don't Plex and Emby both use Gracenote? As far as year, 1 is 2013 and the other is 2016. That's the issue. Why'd you want me to check that? 2016 is wrong. You said you looked in "the guide"? What about doing a search?
MBSki 1115 Posted October 5, 2021 Author Posted October 5, 2021 @cayars Following up. Don't Plex and Emby both use Gracenote? And what do you see when you do a search for The Goldbergs? 2 Programs right?
Carlo 4561 Posted October 5, 2021 Posted October 5, 2021 Clicking on it shows me this But clicking through on the first episode shows this: Three different years for this show 2013, 2017, 2019,
MBSki 1115 Posted October 5, 2021 Author Posted October 5, 2021 1 minute ago, cayars said: Clicking on it shows me this But clicking through on the first episode shows this: Three different years for this show 2013, 2017, 2019, And yet Plex only shows 2013. Aren't they both using Gracenote?
Carlo 4561 Posted October 5, 2021 Posted October 5, 2021 Just a heads up. I believe we understand what's going on with this and different years showing up for the same series.
MBSki 1115 Posted October 5, 2021 Author Posted October 5, 2021 6 hours ago, cayars said: Just a heads up. I believe we understand what's going on with this and different years showing up for the same series. Ok, does that mean there's a way to fix it?
Carlo 4561 Posted October 5, 2021 Posted October 5, 2021 IMHO, yes there is a way to fix this to get the correct information. How this would be implemented or time line isn't for me to say. I've only sent Luke a PM on this hours ago so he will need time to look at it and evaluate it properly. 1
Carlo 4561 Posted October 14, 2021 Posted October 14, 2021 This should be fixed in the beta 14 release. You will need to "force" this to see changes right away. Remove your tuner source and refresh guide. This will purge your existing Guide Data. Remove any scheduled series recording that have this issue (write them down if you have a few). Add your tuner back and wait for the guide to refresh. Recreate your existing problematic shows.
MBSki 1115 Posted October 14, 2021 Author Posted October 14, 2021 46 minutes ago, cayars said: This should be fixed in the beta 14 release. You will need to "force" this to see changes right away. Remove your tuner source and refresh guide. This will purge your existing Guide Data. Remove any scheduled series recording that have this issue (write them down if you have a few). Add your tuner back and wait for the guide to refresh. Recreate your existing problematic shows. Awesome, thanks!!
