Keyboardcowboy 0 Posted August 27, 2021 Posted August 27, 2021 Hi I've tried the filter option played/unplayed but that is not working on the apple TV , it is working for Movies. I've got a lot of tv series 400+ could that be a problem, does anybody else have same issue ? Regards Key
Luke 42241 Posted August 27, 2021 Posted August 27, 2021 Hi there, what exactly do you mean by not working?
Keyboardcowboy 0 Posted August 29, 2021 Author Posted August 29, 2021 (edited) Hi Luke I've created screenshots of the actions I''ll take 1 I'll have the sorting on last episode added (descending) 2 select filter 3 then unplayed 4 click on done 5 And no filter applied , so looks that there goes something wrong embyserver.txt Edited August 29, 2021 by Keyboardcowboy adding log file, removed password/user
Keyboardcowboy 0 Posted August 29, 2021 Author Posted August 29, 2021 (edited) Sorting on Title and then using the filter works , very slow but it works Somehow it looks like the sorting function has effect on the filter Edited August 29, 2021 by Keyboardcowboy
Keyboardcowboy 0 Posted September 14, 2021 Author Posted September 14, 2021 On 8/27/2021 at 8:23 PM, Luke said: Hi there, what exactly do you mean by not working? Hi Luke added screenshots and explanation , does it make sense ? or do you need more , i can make a movie if you want
GrimReaper 4896 Posted September 14, 2021 Posted September 14, 2021 On 8/29/2021 at 1:01 PM, Keyboardcowboy said: Hi Luke I've created screenshots of the actions I''ll take 1 I'll have the sorting on last episode added (descending) 2 select filter 3 then unplayed 4 click on done 5 And no filter applied , so looks that there goes something wrong embyserver.txt 2.28 MB · 1 download I didn't get this one, what happens after you press Done on that last screenshot? Where's the next one?
Keyboardcowboy 0 Posted September 17, 2021 Author Posted September 17, 2021 On 9/14/2021 at 11:02 AM, GrimReaper said: I didn't get this one, what happens after you press Done on that last screenshot? Where's the next one? The thing is nothing happens I'll get back to first screen and the text on the button is no filter, still all shows all 423 are visible and I've tried over and over again.
vdatanet 1619 Posted September 27, 2021 Posted September 27, 2021 (edited) On 9/23/2021 at 9:11 PM, Luke said: @vdatanet are you able to reproduce? No, It works for me. Edited September 27, 2021 by vdatanet
Luke 42241 Posted September 27, 2021 Posted September 27, 2021 31 minutes ago, vdatanet said: No, It works for me. Thanks. We'll try and chase down what the other user is running into.
Keyboardcowboy 0 Posted October 1, 2021 Author Posted October 1, 2021 what kind of testing can i do ? is it related to my huge amount of series that the filter is not working ?, Can't set-up a remote session on my apple tv, but can make a recording with my phone, logfiles, screenshots of settings regards Key
Luke 42241 Posted October 2, 2021 Posted October 2, 2021 13 hours ago, Keyboardcowboy said: what kind of testing can i do ? is it related to my huge amount of series that the filter is not working ?, Can't set-up a remote session on my apple tv, but can make a recording with my phone, logfiles, screenshots of settings regards Key @Keyboardcowboy are you still running into this? Can you please attach the emby server log from when this happens? Thanks.
