trampmasta 1 Posted August 24, 2021 Posted August 24, 2021 All of my channels show up but when trying to map the guide data in the settings it doesnt show any channels there and wont let me map them like i was able to before.
Solution Carlo 4561 Posted August 24, 2021 Solution Posted August 24, 2021 Hi, When I've seen this it was because of bad EPG guide. Are you using an XML guide source?
trampmasta 1 Posted August 24, 2021 Author Posted August 24, 2021 Yes i am, I havent used it in about a year and just recently set it back up.
trampmasta 1 Posted August 24, 2021 Author Posted August 24, 2021 Just now, trampmasta said: Yes i am, I havent used it in about a year and just recently set it back up. I did just notice i had two old EPGs in there. clearing them out and refreshing to see if that does it!
trampmasta 1 Posted August 24, 2021 Author Posted August 24, 2021 Thank you @cayars!! that was all it was 1
