jglazer63 23 Posted August 24, 2021 Posted August 24, 2021 I just pressed my remote's FF button maybe 1000 times to get to where I left off on a 3 hour movie. What remote button fast forwards more than 15 seconds? I would assume there is one. Like FF a minute? I have a universal remote, is there a way to program this?
Happy2Play 9811 Posted August 24, 2021 Posted August 24, 2021 Not specifically related to you question but are you saying Emby is not recording your Resume point for this media? As Emby should pick up where you left off. 1
FrostByte 5453 Posted August 24, 2021 Posted August 24, 2021 You can go to Playback settings to change the value, but I believe 30 seconds is the max you can FF at a time. On a Samsung remote it's the Right click The easiest way to get where you want though is to use the chapter skip within the OSD and then FF 30 seconds at a time from there. Chapter skipping was added in v1.1 A timeline slider type advancement is supposedly in the works
jglazer63 23 Posted August 24, 2021 Author Posted August 24, 2021 57 minutes ago, Happy2Play said: Not specifically related to you question but are you saying Emby is not recording your Resume point for this media? As Emby should pick up where you left off. I was afraid someone would key into that lol. It was my fault, I miss-clicked "play from beginning". 1
jglazer63 23 Posted August 24, 2021 Author Posted August 24, 2021 16 minutes ago, FrostByte said: You can go to Playback settings to change the value, but I believe 30 seconds is the max you can FF at a time. On a Samsung remote it's the Right click The easiest way to get where you want though is to use the chapter skip within the OSD and then FF 30 seconds at a time from there. Chapter skipping was added in v1.1 A timeline slider type advancement is supposedly in the works I will look into chapter skip but I don't think there's any chapter markers in the file. What button on the remote does this?
FrostByte 5453 Posted August 24, 2021 Posted August 24, 2021 By default I believe Emby should add 5 minute chapters in the db if no chapters are available in the mkv, etc. Not sure what it's technically called, but on the Samsung remote the circle that's used for movement (left, right, up, down) if you click the right side og the circle it will FF 30 seconds. Left is RW
jglazer63 23 Posted August 24, 2021 Author Posted August 24, 2021 2 minutes ago, FrostByte said: Thanks for the photo! I'll look. I am using a universal remote but I can grab the original remote to see if that does it. Thanks again!
