AgileHumor 123 Posted September 1, 2014 Posted September 1, 2014 (edited) So, I've been using F.Lux on my MBC (and testing MBT) HTPC to slowly remove blue light. I also do this with Vera + Hue Lights (going from white/blue in day...to yellow at sunset...and orange after 10pm...and red at bedtime (button or auto at 11pm). On my desktop PC, I use a more aggressive indecent (needing the reboot). Really helps when working late night. Turning it off after using all evening is quite drastic on the eyes to get that bright brue/white light. If you don't use it on your HTPC, i highly suggest you use it on your PC's and IOS devices. http://justgetflux.com PS - There is no way to keep "Movie Mode" forced, but I haven't noticed a big difference with movied mode on my 1080p displays. Hopefully more options will come with time. PSS - Alt-PgDown also makes the picture backlight dimmer. I haven't tried this on the HTPC but use it on my multi-mon desktop setup. Edited September 19, 2014 by AgileHumor
Spaceboy 2573 Posted September 1, 2014 Posted September 1, 2014 S.pam? Sent from my iPhone using Tapatalk
AgileHumor 123 Posted September 1, 2014 Author Posted September 1, 2014 (edited) Ya, if blue light is spam for the eyes. It's free download there @@Spaceboy if you actually looked before passing your incorrect judgement. PS - Not related to author in any way and benefit in no way if you use this FREE software. Edited September 1, 2014 by AgileHumor
porkbone 48 Posted September 5, 2014 Posted September 5, 2014 Been using it for a couple of years on my bedroom media center and love it!
AgileHumor 123 Posted September 19, 2014 Author Posted September 19, 2014 (edited) Thanks, updated link in OP Edited September 19, 2014 by AgileHumor
