Joechung 5 Posted August 22, 2021 Posted August 22, 2021 Where is the default metadata folder? I have changed the path and my metadata. The actor has a problem and becomes blank.
Luke 42240 Posted August 22, 2021 Posted August 22, 2021 The default is under the server's data folder, then /metadata. The data folder path can be found at the top of the server log files. When you change the metadata path, it is up to you to migrate the existing files, although we need to update the user interface to make that more obvious.
Happy2Play 9811 Posted August 22, 2021 Posted August 22, 2021 Something like Data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata/metadata. But the database entries should be pointing to the original location per the time the item was imported. Only new items should be looking in the new custom location, unless something has change here that I did not know.
Solution Luke 42240 Posted August 23, 2021 Solution Posted August 23, 2021 Has this helped you resolve this?
Joechung 5 Posted August 23, 2021 Author Posted August 23, 2021 2 minutes ago, Luke said: Has this helped you resolve this? In fact, there is no real solution. I removed all the media library and rebuilt the media library.
Luke 42240 Posted August 23, 2021 Posted August 23, 2021 Just now, Joechung said: In fact, there is no real solution. I removed all the media library and rebuilt the media library. Didn't we give you the solution? Or did you not try it?
Joechung 5 Posted August 23, 2021 Author Posted August 23, 2021 2 minutes ago, Luke said: Didn't we give you the solution? Or did you not try it? I re-established the media library before finally solving the character avatars.
