Chenc033 0 Posted August 22, 2021 Posted August 22, 2021 So my tcl p715 tv has a 100mbps ethernet and i get buffer issues with high bitstreams remux files over emby. I got a ugreen axis 88179 usb to ethernet dongle that works with the internet. However the emby app cannot connect to the emby server over the usb to ethernet dongle.. i get the com.android.volley errorneither can plex..any one has any ideas?
ebr 16338 Posted August 22, 2021 Posted August 22, 2021 7 hours ago, Chenc033 said: neither can plex Hi. This would indicate that the issue probably lies at the device/network level. Have you properly setup the network interface?
Luke 42246 Posted August 24, 2021 Posted August 24, 2021 Quote However the emby app cannot connect to the emby server over the usb to ethernet dongle Are they on the same local network? Is there a local network when connecting them this way?
Chenc033 0 Posted August 24, 2021 Author Posted August 24, 2021 Yes they are. I have resigned that it’s probably a hardware or android 9 or driver issue between the tv and the ugreen adapter
